Question about HP PSC 1410v All-in-One Printer
My printer says it's out of paper, but I have paper loaded and noticed I was out of color ink so I ran to get some. When I loaded the ink cartridge it printed the ink alignment sheet. So I figured it would work and tried printing again. This time it said I was out of Memory. What is wrong?
  • HP Master
  • 10,459 Answers
Tonerman
  • 62 Answers
SOURCE: Error after reloading color ink
try re-installing the printer freshly with the driver .
Posted on Jun 10, 2007
danasaur
  • 77 Answers
SOURCE: Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Posted on Dec 12, 2007
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
  • 32 Answers
SOURCE: lost my HP 1315 alignment sheet...machine won't print one.
ya u r correct the catridges wil be out of ink
u check the ink
the alignment wont be wrong
Posted on Mar 17, 2009
JULIANFIX
  • 975 Answers
SOURCE: turn off the setting align ink catridge
go to SETTINGS , then go to DEFAULT of FACTORY DEFAULT click here, turn off PRINTER then turn ON again , see what happens , let me know , AJ
Posted on Aug 08, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
When i replace with new original 818 color and black/white ink cartaiges the ink status show as b/w full and color iswith"x" mark(no ink) and printer can"t take paper i also re load the driver software
If there is an "X" on the color cartridge indicator then there is a problem with it. If you have removed the plastic tape that covers the part that connects to the computer and you still have this problem then the cartridge is defective and needs to be returned to the store and exchanged for another that is good. Exchange the cartridge and install the replacement. This should solve the problem with the printer not recognizing a full color ink cartridge.
You mentioned that the printer cannot take paper. Please clarify what happens when you load the paper tray and try to print? Are you loading paper one page at a time using the external feeder or are you loading the paper tray full with paper before trying to print? If your loading page by page or filling the tray with only a few sheets of paper then try loading a bigger amount of approx 1/2" of paper. It is easier for the printer to grab paper when the try has a good amount in it. If it still will not load the paper when the tray is full and inserted correctly, please advise what happens when you try and print - exactly? Does the printer respond to the print command sent from the computer? Does it make attempts to load the paper and then fail and stop? Does it pick up paper and then show a paper jam? Does the printer do anything when trying to print from your computer? Answer these questions and I will help you solve this problem right now.
Sep 27, 2010 | HP Deskjet 3420 InkJet Printer
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Ink and printer
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
HP PSC 1410v All-in-One Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
