Question about Olympus VN-3100PC Digital Voice Recorder
Vn-3100 non pc
Everything works but when i plug ear phones into jack no sound comes out.
  • 2,794 Answers
I beleive that recorder is mono. You have to use an adapter for stereo headsets or listen on one side of the head set.
Accessories are available at olympus.com
Posted on Sep 02, 2008
Headphones
Hi
Try them in another device to eliminate a faulty jack, if they still dont work the head phone may be faulty, return to seller and ask for a refund or replacement.
But also try a different head set in the jack to see if the jacks working properly.
Cheers
Nov 23, 2012 | Steel Series SteelSeries 7H Headset -...
My ear phone audio out put not working
Back or front of the PC??
If rear ensure its plugged into the green socket.
Do speakers work out of this port??
Mar 24, 2010 | Computers & Internet
I have a Olympus VN3100PC. It was working fine and I hooked it up to an ear jack and for some reason it no longer will play sound. Any suggestions?
There may be dirt or something in the ear jack that is shorting out the out put.try using the proper plug on a earbud or head phone and see what happens
Feb 19, 2010 | Olympus VN-3100PC Digital Voice Recorder
I have turned the tv on and in the top right hand corner there is a symbol for earphones and i cant get the normal sound back on
yoiu likely have a sound output selection in you setup menu .. or in some sets they sense the fact that ear phones are plugged in (switch in the ear phone jack) .. and that automatically shuts off the main speakers .. sometimes the ear phone jack gets damaged and the set thinks there is always an earphone plugged in .. if thats the case then the jack would have to be replaced or repaired ... or you could for the time being, run a cable from the ear phone jack to an external amplified speaker (like a computer speaker .. that would get your sound back at least until repairs can be made ..
Nov 27, 2009 | Cell Phones
Sound plays distorted but sound card is working .
Sounds like you need to check the connection to your sound system. Could be the jack is not in properly or there`s a short in the cable to your soudn system. Check the cable if necessary. You might also be overloading the input on your soudn sytem so try to reduce the volume of the computer and raise the volume on the sound system. If your cable is shorting or coming loose inside the jack you will have problems.
May 14, 2009 | Dell Dimension 3100 PC Desktop
I can't conect my recorder to my PC
If it is a VN-1000 it is not designed to be interfaced with a computer as there is no USB port on the unit at all. If you wish to transfer the files you can purchase what is called a compaticord or patch cable that will connect through the ear jack of the recorder to the mic jack of the computer to be able to transfer the information on to your computer.
Apr 13, 2009 | Olympus VN-1000 Digital Voice Recorder
Headphone Jack is NOT working properly
Check your sound device levels. you may need to enable that headphone port before it is usable. you can do this in the control panel tab. reinstalling your sound drivers wouldn't hurt also.
Jan 28, 2009 | Toshiba Satellite A105 Notebook
Vn-3100
use a compaticord and plug from the earphone to the mic of the pc and use sound recorder to record the message
May 16, 2008 | Olympus VN-3100PC Digital Voice Recorder
Volume is non-existant on LG VX 4400
When you press vol up & down it will indicate "ringer ear jack." This means the phone is stuck in ear jack mode expecting a wired head phone accessory. Remove the battery then unscrew and pull out the antenna and the black plastic sleeve. Then remove the for small torx screws and carefully remove the back. Take a tooth pick to the back of the ear jack an bend the retainer pin back. Put everything back in reverse order and it should work fine.
Nov 28, 2007 | LG VX4400
Acer 3680 sound on headphone
I wish I knew what you was asking when you plug the ear fone into the right jack everything goes good but theres no sound in the earplugs yet wen you eject it puts a ballon on the screen sayin no jack is in the plug can you explain what you want......... its bugging me Im not sure what you want and Ive rad your problem four times.
Aug 30, 2007 | Acer Aspire 3000 Notebook
Olympus VN-3100PC Digital Voice Recorder Logo
47 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
