Question about Microwave Ovens
GE spacemaker xl1800 microwave has no power
My microwave receies no power at al. It's not the outlet as other applicances work in that outlet. we get no power, no lights or anything. It may be afuse but i donot know where to check for it. how do i access he fuse box. We purchased it in 8/2001, maybe it is time for a new one
  • R8EDM Mar 29, 2009
    Mine is pretty much the same, but the microwave deteriorated over a short period of time. It started by clicking, like a relay going on and off but very quickly, when we tried to either microwave or use the light/vent. The clock worked fine during this time, but eventually even the clock went out rendering the unit useless. Any idea on where to start?
    Thanks!
  • GlennSk Apr 21, 2009
    I have a spacesaver xl1800, it is about 3 years old. It has had no problems at all, then the lights went out. No power to the key pad, no light in the over when the door is open. I did replace the two fuses, (H.V. and Main Fuse) with no change. Of course, i check the outlet to ensure that it is working. Any suggestion on the the step?
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
I had the unit repaired by an appliance technician. He replaced the board behind the keypad and all is well now.
Posted on Jun 05, 2009
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Disconnect the wire connection on touchpad
Do you mean the keypad strip?
Jan 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
2,763 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
