Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Trouble with newly installed thermostat
The Thermostat is programmed to 78 degrees but when the unit is turned on the temperature goes up to 84 degrees and holds there. What could be causing this .
  • Anonymous Jul 20, 2008
    temperature is set on 75 temperature in house is 85
  • Polaroidlady Aug 04, 2008
    the tempature is set at 78 degrees but the when the unit is on the temp thermostat displays 88 degrees
    Problem Solver:
  • 5 Answers
Did you program your own temps, if not i believe this is part of default program!
Posted on Jul 11, 2008
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
I turn my heater on, it is set on auto, but it never turn off, it's a new thermostat.
If the setting was at 80 degrees and it didn't turn off, that's because the room didn't reach 80 degrees yet. Keep track of the room temperature as well as if it turns off when set for a lower temperature.
Dec 28, 2012 | Honeywell Programmable Thermostat Heater
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
I set the Hold temperature to 78 degrees but the room temperature has now climbed to 84 degrees. Thermostat issue or air conditioning issue?
Is the air coming out of the vents cool? There should be roughtly a 20 degree difference between the air going into the return air vent and the air coming out of the supply vents. If this is close, then it could be a thermostat issue, but check your air filter, make sure that the return air vent is not blocked, and all supply vents are open. If you had to fix any of the above, the indoor coil might be iced up and if that is the case the air flow will be greatly reduced.
Turn off the A/C and let it set for a 24 hour period, or turn it to off and then leave the fan only on, overnight. Then try again, if it's iced again then you will problably need a tech to look at it,
But to me it sounds like an A/C issue.
If this has been helpful, please rate me, and also contact me back with any questions, that you have.
Sincerely,
Paul Gibson
May 02, 2010 | Honeywell Programmable Thermostat Heater
Furnace runs but does not heat up the house to thermostat tempera
Did this problem just start? Or has it been a long term issue? Check for broken ductwork, return air pulling outside air in. Check supply air temps, should be 100-140° or more. And what is the outdoor temp? If it's 0° outside, 74° is doing good. Is the home insulated properly? And there is a small hole behind the t-stat where the control wire comes through the wall. Plug that hole, seal that hole to prevent cold air from fooling the t-stat. The furnace has 3 fan speeds and it may be in low speed. If so it should be in medium speed. I'd suggest a service tech doing this for you unless you are experienced in furnace repair.
Nov 02, 2017 | Goodman Heating & Cooling
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
152 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
