Question about Kenmore 23822 Top Load Washer
24642300 doesn't spin
It doesn't spin on the regualar cycle. it works fine in the heavy duty cycle. it will work if i manually turn the dial to spin and pull. otherwise it just skips over the spin cycle. timer problem?
  • 2 more comments
  • y_ebbi Jun 30, 2008
    24642300 model number
    it's the final spin cycle that doens't work, the 1st one works fine
    ty, i'll start checking around for prices.
  • LSTONE89 Nov 27, 2008
    EVERYTHING WORKS,EXCEPT SPINNING WATER OUT.
  • 481 Answers
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Posted on Jun 30, 2008
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Will not spin
You have either a bad lid switch, a bad drive coupling or a bad timer. If you can move the timer dial to spin manually and turn it on and it spins the lid switch is good and the timer is bad. If you manually move it to spin and the motor runs with no spin, the drive coupling is bad. If you manually move it to spin and nothing happens, the lid switch is bad.
Jun 11, 2009 | Kenmore Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Doesn't spin
Jun 30, 2008 | Kenmore 23822 Top Load Washer
GE Washing machine not cycling
"...can hear the electrical contacts trying to hit". The timer may be defective.
Oct 05, 2017 | GE Washing Machines
Kenmore 23822 Top Load Washer Logo
142 people viewed this question
Sal De
fordexpert
Robert Rankin
