Question about Miele Washing Machines
When I use cold wash on my Miele W830 the water heats. Any solutions?
  • 481 Answers
Check the water connections going to the back of the machine, you may have the hot and cold mixed or reversed. if you turn it on hot water will it dispense cold water?
Posted on Jun 30, 2008
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
Have a Miele 1612 washer whose heater element comes on during any cold only program. As we are off-grid, any unnescesary power useage is unacceptable. Is there something I can reset, or do I just remo
Hi Ed ..
The following is from the Miele handbook and would indicate that the machine can have the water temperature adjusted...... However I suggest that by merely disconnecting/removing the element
the machine's temperature sensors would not allow the machine to work..
A compromise may be to select the lowest wash temperature (ie 30c) This is better than cold water for detergent economy and effectiveness, and machine life.. I understand your situation.
Good luck
Nomess
http://m.miele.ca/OperatingInstructions/en-CA/Laundry/Washing%20machines/Previous%20models/Miele%20Washing%20machine%20Manual%20W1612.pdf
Page 50
Tap water line (cold water) The tap water connection is established using the inlet hose with the blue marking. If the washer is connected to this line only, the appliance will need to be reprogrammed to cold water fill only. Please contact your Miele dealer or Miele Customer Service for reprogramming instructions.
Feb 05, 2015 | Miele Washing Machines
Miele W830
Yes your diagnosis is correct. We had the same on a machine that had done 12,400 washes on a life expectancy of 8,000 washes. Great machines. Airport lounge washing dozens and dozens of towels every day, 7 days a week.
Our machine had a sensor that doesn't let the machine spin at full speed if the drum is out of balance. It was something like a WS3120. We swapped it out for a much larger Miele.
Dec 04, 2017 | Miele Novotronic Premier 500 Front Load...
Is the indecit wm12x washng amchne a hot or cold water fill?
Hi from retired Englishman in SW France @ 13:45 Tues afternoon.
You can easily check by looking at the back where the water pipe or pipes need to be connected. If there is only one inlet then it is a cold fill and the machine will heat the water up itself.
If there are two inlets the hot is normally marked RED and the cold BLUE.
When the hot water is not hot enough for the particular wash, the machine will heat it in the same way as it would heat just cold water. If, however, the hot water is too hot, it will mix in some cold!
Cheers,
John C
Feb 08, 2011 | Miele Washing Machines
W830 washing machine stops before end of cycle.
could be something to do with the drain pump, the machine gives itself 3 mins to get bellow a water level before it spins, if it cant make the water level in 3 mins it stops because the weight of the water and clothes would be too much for the machine that would start to dance the tango, check the pump and sump for minor blockages first.
Jul 23, 2009 | Miele Novotronic Premier 500 Front Load...
Water not getting into washing machine miele novotronic w830
Thank you for advice! My Miele Novotronic W830 is 17y old, been working well, until yesterday. When taking water, much started spilling on floor under the left lower corner of the machine.
I opened the cover, found a loose hose under the detergent tray, did set it back in place and tightened the band.
First you better loosen the band, it slips more easily on the funnel.
In my photos you can see the screw is pointing to wrong direction to be able to use a screwdriver, but I did manage it with bare hands.
Be sure there is no power connected when opening the cover!
And don't drop anything inside, when opened the cover, it is a nasty place to get it back...8_26_2012_3_23_27_pm.jpg8_26_2012_3_24_22_pm.jpg8_26_2012_3_24_47_pm.jpg
May 10, 2008 | Washing Machines
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
152 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
