Question about Kenmore 23822 Top Load Washer
Doesn't spin it doesn't spin on the regular cycle. if you manually put the dial on spin cycle and pull the knob it will work. otherwise on the normal cycle it just skips over it. the spin cycle works fine on the heavy duty cycle. do i have a timer problem?
  • y_ebbi Jun 30, 2008
    model number 24642300 top load
    p.s. it's the second spin cycle that doesn't work. the first one works fine
  • 481 Answers
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Posted on Jun 30, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Will not finish cycles, two hours later I will look and the tub is full of water or it may not finish spin cycle. Suspect the control timmer?
The timer mechanism is faulty. The timer is the mechanical computer of any washing machine. It simply works by connecting different circuits together for a predetermined time. If a particular cycle isn't working, the timer unit will need to be replaced. You can manually advance the timing unit by pulling out the knob in the middle of the unit, rotate the dial to the desired cycle then push the knob in- that will start that cycle. Good luck, Jim
Aug 28, 2009 | Washing Machines
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
24642300 doesn't spin
Jun 30, 2008 | Kenmore 23822 Top Load Washer
Kenmore 23822 Top Load Washer Logo
143 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
