Question about GE RCA G.E. Thompson 25414RE3 4 line corded phone
Secure my router.
Can you please run through the procedure on how to secure my router, i,m an old guy on a new laptop, thanks. i need help to secure my router
    Novelist:
  • 94 Answers
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Posted on Sep 06, 2010
Laptop Can't Find New Cisco Linksys EA4500 N900 Router In Setup
Try this, your IPS Virgin, is a modem? remove AC from the ISP modem and remove battery(If it has one), remove AC power from the Linksys. Insert battery and plug in the virgin ISP modem, allow it to run the self test, may take a few mins. Plug in the Linksys, ( Is it secured with a SSID and security code?), wait for self test. turn on your computer boot normally. If that fails try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
Dec 02, 2012 | Linksys by Cisco Linksys Ea4500 Dualband...
Help with d-link router please
Thanks, konafaa. Sometimes the best procedure is to start over from the beginning, as you discovered.Best regards!
Apr 19, 2012 | D-Link Computers & Internet
I am connected to my router on my laptop, and I am trying to connect a second laptop to the same router. Problem is I did not write down my WEP password and it is grayed out so I cannot retrieve it. I...
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blankand the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
Feb 27, 2011 | Linksys Wireless-G WRT54G Router
New lenovo laptop won't recognize belkin router {okay on desktop and old laptop}; new one wants a security code.
yes router is working good but your new laptop maybe operating system ned to be configure manually or reinstall wireless security in to your router
advise you to setup your security mode in to 64bit WEP is your new laptop use a windows 7 or vista.
let me know
please rate me techbelkin
Aug 26, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
VALIDATING IDENTITY
I've also had this problem when trying to connect my Medion Laptop through a Netgear Range Extender. It would find the router wirelessly but not through the Netgear. I had tried every solution on the web for days without success. Thanks to this page and a contributor who suggested updating the driver (which I had thought of previously) I did that and it all works fine. My laptop is 7 years old and wouldn't recogise WPA-PSK which was the setting on a newly installed router.
Update your Driver. :)
May 26, 2010 | Linksys WRT160N Wireless Router
How to secure DSL-G604T modem
You can set your router on factory reset mode with help of reset button and and after that you can connect your new laptop and then you can re - configure your router again with help of
http:\\192.168.1.1
Username and Password is "admin"
Mar 30, 2010 | D-Link DSL-G604T Wireless Router
Can connect desktop to internet but having trouble connecting laptop to internet
First of all get your connection to teh laptop from the router wired. Then, please ping the routers IP ( Start --> Run -- > cmd --> ping 192.168.x.x.)
Look at the manual for routers IP address.
If you are getting four replies, you have a valid connection, else, try changing cables or ports in the router.
Once this is done remove the cable, try wireless. To do that, ensure, to start off, there is no security on the router. Repeat the ping procedure keeping the router closer to the laptop ( for a good signal strength )
If you are not going online yet, let me know what happens.
hope this helps
Thanks
Ranjit
Jan 05, 2010 | Belkin (F5D7230-4) Router (587009)
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
How do I copy the security key?
the solution to this one is you need to reconfigure the router. you need to disable the security settings for your router. (WEP or WPA) then try to put in a new SSID and new security key. that's the only way that you can get a new security/passphrase key for your network. for further assistance you need to contact the router manufacturer for router configuration.
i hope this helps.
Sep 13, 2008 | Computers & Internet
Secure my router.
Configuring WEP:
Connect a computer to any one of the four LAN ports of the Belkin wireless router.
Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Jun 13, 2008 | Belkin (F5D7230-4) Router (587009)
Lands Phones Logo
111 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
