Question about Janome Memory Craft 9000 Computerized Sewing Machine
Cotton keeps getting caught up in bobbin - Janome Memory Craft 9000 Computerized Sewing Machine
Make sure you clean it often. Also, try using a thread with a lower lint output. I know some of the thread I use has a coating on it to keep it from causing too much lint and clogging the machine.
Posted on Jul 21, 2008
A thread is caught in the bobbin apparatus. Took bobbin case out and machine is still jammed. Can I take it apart and get the threads out? What to do...
Only thing is to remove the bobbin, bobbin holder if you can, the feed dog cover plate, and then, using a magnifying lamp and a fine pointed pair of tweezers, try and locate the bits of cotton and pull gently out while rotating the hand wheel slowly, rocking it back and forth. Use an air blaster can to blow fluff out, clean, and oil. Including inside the bobbin case.
Feb 26, 2017 | PfaFF Sewing Machines
Why does the needle keep breaking?
not really sure ,have you made sure there is no cotton caught in the bobbin case ,also are you using the right size needle x
May 21, 2015 | Brother XL-2230 Mechanical Sewing Machine
The cotton keeps getting caught up in the bobbin area
try these suggestions
1. change needle--flat side to the back of the machine
2. needle must the correct one for the fabric
3. check the bobbin to make sure it's not damaged or warped
4. check the bobbin case( the thing that holds the bobbin) to see if there
are any burrs on it or see if it's damaged is some way
make sure the bobbin case fit's snuggly into the hookrace's also possible that the machine could be out of time
Apr 18, 2012 | Sewing Machines
Tension problem old singer sewing machine
try rethreading the machine top & bobbin to make sure the thread is not caught
change the needle
if the tension dial does not respond then the dial may need to be replaced
Apr 12, 2012 | Singer Sewing Machines
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
The bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Oct 19, 2008 | Singer 15ND Mechanical Sewing Machine
Replacing the bobbin case
Remove the bobbin and drop a little oil in the bobbin holder at the center which you usually insert the bobbin...
Happy Fixya... keep me posted on the result....
Feb 05, 2008 | Singer 7436 - INGENUITY
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
