Question about Microsoft Office Professional 2007 Full Version for PC
  • Tim Babcock
    Tim Babcock May 11, 2010
    What operating systems are you using?
  • 3 Answers
As it is always said that working with the registry is always dangerous. Anyways, what has been done is done.
If you used some registry cleaner program to delete the registry keys, Most probably you would have made a back-up of your registry as well at some time in the past.
Try locating the Back-up file & then you can simply add the values by double-clicking on the *.reg file. If there is no back-up alas, i don't think there is much what can be done.
The best possible & easy solution would be a complete OS re-install.
Good Luck.
Posted on Jul 15, 2008
I want to know how to activate cheats in crossfire
Follow this link for the original instructions:
1. Go to your CrossFire folder in Windows Explorer.
2. Right click on the kknd2.exe file and select create shortcut.
3. Right click on the newly created shortcut and select properties.
4. In the target field, add "-badnews" to the end of the line. It should look something like this: "Kknd2.exe -badnews".
5. Click OK
6. Double click the shortcut to begin CrossFire.
7. While in game, press Ctrl-Tab to activate cheat codes.
Here are some common cheat codes:
CTRL-M = Extra money.
CTRL-C = Win level.
CTRL-F = Lose level.
CTRL-W = Turn on waypoint information.
CTRL-E = Turn off waypoint information.
CTRL-T = Turn off the fog of war Command line parameters.
More hints are available at the above link.
Good luck and thanks for using FixYa.
Mar 05, 2011 | Computers & Internet
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cannot open Reader on Desktop - click the icon and nothing happens
If you mean Adobe Reader, then either the shortcut has lost the information on what file it is associated with or Adobe Reader is no longer on the computer. If you recently transferred to a new computer using the Windows Transfer Wizard, the shortcut may be pointing to a different version folder or to a not yet installed program. Remember the Transfer Wizard does not install the programs and doesn't transfer the registry information about installed software from the old computer.
For Windows:
First, right click on the icon and then click on Properties. That will give you the location and name of the program it is associated with (as it was created). For example: on my Win7 32-bit machine this reads "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe". Next open the Control Panel Programs list, see if Adobe Reader is listed. (For Win7, this is Start > Control Panel > Programs. WinXP, look for the Add and remove programs section.) Open Computer (My computer) and navigate to C:\Program Files. See if you have an Adobe Folder and then the reader folder location. (If the folder exists, check for the exe file and if that full folder name matches the one for the shortcut.)
If Adobe Reader isn't installed, go to and follow the link on the right hand side to download and install Adobe Reader. Then remove the bad shortcut since a new one will be added to the desktop.
If you have Adobe Reader installed but the shortcut isn't pointing to the correct location, you can create a new shortcut by right clicking on the exe and choosing create a shortcut. Before you do this, double click on the reader.exe and check that it does launch. Otherwise, uninstall and reinstall the program.
I hope this helps.
Jan 12, 2011 | Computers & Internet
I down loaded a HP Deskjet F4280 DRiver and I dont know how to put a short cut for the scanner
Open your Prgram files dirctory and open the folder for your scanner. Click the "View" on top bar and set it to "details". Listed there somewhere will be at least one, probably more, .exe files. Find the .exe file that opens the scanner ( look for SCAN in the name) open it to make sure it is the right file, then right click it and choose "create a shortcut" which will create a shortcut on your desktop. It is also possible in some configurations to get a "send to" option when you right click, where you can choose to put a shortcut somewhere else, possibly Quick Launch. There may also be a choice in the context menu to "add to startup" which will put a shortcut in your startup list.
Oct 30, 2010 | Computers & Internet
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
Sep 03, 2010 | Online Computers & Internet
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    I have had an account with AOL for years without a problem but when I click on my desktop icon it will not open. What has happened and how do I fix it?
    AOL shortcut was created on your desktop. Due to some technical issues, the configuration might have changed. Do not worry. I will help you to re-create another shortcut of AOL on your desktop for one time click and work,
    When the AOL software is installed, a shortcut is created on your Windows desktop, allowing you to quickly and easily sign on. If your desktop icon is missing, or if it points to a version of the software other than the one you would like, follow these instructions.
    To create an AOL icon on your desktop
    1. On the Start menu, select Programs, then click Windows Explorer (on Windows XP, select All Programs, Accessories, then click Windows Explorer).
    2. Browse to the folder that has your AOL software (e.g., C:\Program Files A File is an electronic document which can be text, pictures, sounds, videos or whole programs. Reminder: Never download files from someone you don't know. Files may contain dangerous Trojan Horse programs that may capture your AOL password, severely damage your computer, or contain objectionable graphics. To report a violation in an attached file, please forward the e-mail to screen name TOSReports.\America Online 9.0).
    3. Click the file waol.exe once to select it.
    4. On the File menu, click Create Shortcut.
    5. Drag the new shortcut icon (Shortcut to waol.exe) to your Windows desktop.
    You can rename your shortcut to something more meaningful to you. Simply press F2 on your keyboard while the shortcut is selected, type a new name, then press ENTER.
    To delete a shortcut, drag it to the Recycle Bin. Your AOL software will still be on your computer.
    That should work. For further reference, click the link;
    Anirban Mazumdar
    Jun 04, 2010 | E-Machines eMachines Desktop PC
    Corel Paint Shop Pro X will not respond or open
    Please inform corel from the internet and tell them that you purchased the 2007 version of paint shop Pro. tell them that you needed to install back unaccessed software.
    Jul 09, 2009 | Corel Paint Shop Pro® X Full Version for...
    My problem is with MS Photo Editor bundled with Office: I can no no longer run it in a ''normal'' sized window. When I use it to open a JPEG, it starts out minimized, and R-clicking on the taskbar icon and...
    Try this:
    Find the MS photo program on your hard drive (I believe, but am not sure, it is located here: C:\Program Files\Microsoft\Photo Editor.Exe Create a shortcut (right click on Photo Editor.exe and choose create shortcut) to the program. Then, after the shortcut is created, RIGHT click on the shortcut and click on properties. In the properties windows that pops up, find "run probram MAXIMIXED and make sure that is checked." then, click on OK a couple of times until you can see the "shortcut to photo editor.exe" shortcut. Double-click on that shortcut, which should start photo editor maximized.
    Woo Hoo.
    Now close photo editor.
    Hopefully from this point on every time you open photo editor it will open maximized because you have just tweaked the registry to do so...
    Take care,
    Mar 05, 2009 | Microsoft Computers & Internet
    No new icon even after the program shows successful completion
    OK, if the program can be found in the start menu, (Start/all programs/ "the program")
    Then right click on it and select " Send to> " move across the next select box which appears and select " Desktop (create shortcut)
    If your program isn't in the start menu, then go Start / Control Panel / Add or remove programs (XP) OR Programs & Features (Blista) check if the program you installed is listed, if it isn't reinstall it, if it is, Right Click on Start and select "Explore" Find the Folder in the tree called Program Files, in that folder find the Folder with your program name, in that folder drill down to you find the program name .exe (it will be type Application) double click and find the one that opens the required program eg. CinePlayer is here, Local Disk (C)/Program Files/ Roxio/Digital Media Plus/CinePlayer/CinePlayer.exe
    Right Click and select Desktop (create shortcut) and/or Pin to Start menu
    Sep 28, 2008 | Computers & Internet
    Microsoft Office Professional 2007 Full Version for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
