Question about Smeg CSU2001 Built-in Dishwasher
SMEG dishwasher program numbers worn off
Hi
Just moved into a new place which has a SMEG dishwasher model PL945. It's a stainless steel one, an on-off button on the top left, then 4 pictures on the right - representing soak, pots, plates & glasses, and rinse.
Looking at the dial and around it, there are no program numbers to be found anywhere except a single arrow key on the dial. According to an online manual, there's meant to be four of them (1-4). It appears the markings have worn off.
Can anyone help with indicating where each program number is located? E.g. 1 = 3 o'clock, 2 = 6 o'clock etc?
Thanks!
  • anniegray101 Mar 17, 2009
    Exactly as above - can anyone help?
2 Suggested Answers
  • 209 Answers
SOURCE: Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Posted on Sep 29, 2007
Hi can any body tell me whats wrong with my smeg dishwasher it only has program lights which now do not come on at all a part from the power light which beeps/but after that nothing
Probably computer is corrupt. Go to your circuit breaker panel and remove power from the dishwasher for a full minute. THEN< POWER back on. That should reset the computer.....
Jan 05, 2012 | Smeg 24 in. DWF614SS Stainless Steel...
I own a KUDS01FLSS3 KitchenAid and the bottoms on top have worn through. What is the panel number for the panel?
I'm not sure what panels you are looking for. I know Appliance Art sells custom stainless panels for the dishwashers that allow you to slide out old panel and insert new one. They also have stainless steel "rolls" for wrap-around dishwashers. www.applianceart.com
Sep 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishes are still wet after the cycle has finished why?
Hi.
Ensure that there is no water at the bottom of the tub. If there is water, check drain well and drain hose, then test pressure switch in the drain system.
If there is no water, the the thermostat (or the dryness) sensor must be replaced.
In that case, cintact Smeg at the number listed on the owners manual.
Regards.
May 02, 2010 | Smeg 18 in. STX45-1 Stainless Steel...
Missing Instruction manual smeg dishwasher SA945X
try going to servicematters.com. You can download owners manuals there.
Apr 03, 2009 | Smeg 18 in. STX45-1 Stainless Steel...
Dishwasher manual
Hi Rosemarygard,
You filed this question under Smeg DWF614SS. You can get the manual for that model here- http://www.smegtech.com/site/smeg/pdf_libretti/19590081906-GB.pdf.
Searching for model M4608AL isn't leading me anywhere, so hopefully it's some sort of subcategory of the DWF61466. If you realize that your Smeg is another model, go to this page and type your model into the field on the left- http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN.
I hope this helps.
Jan 25, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
SA280X or SE280X?
go to google then click on shopping it is the best way to get items hope this helps.
Oct 17, 2007 | Smeg SE280X Stainless Steel Electric...
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Smeg CSU2001 Built-in Dishwasher Logo
134 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
