Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Brother fax 560
Message says top cover open pls close cover
  • 30 Answers
Check the cover sensor arm if it still in place or check the cover hinge or lock if its still good.
Posted on Jul 29, 2008
The Samsung sf-560 is spitting the faxes etc. out of the back of the machine... how do I stop it from doing this and restore the output to the front tray?
The output cover in the back of the Samsung is most likely in the up position. When it is then all output will come out the back of the sf-560. To stop this from happening just close the back output cover by pushing it back down and closing the back cover. Then your output will come out the top shoot.
Jan 23, 2015 | Samsung SF-560 Plain Paper Laser Fax
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    My Brother 560 says top cover open when the cover appears closed.
    Make sure the covers are completely closed. Open each section an close it making sure it closes with a click. Also check for covers under other covers.
    Hope this is of some help.
    ED
    May 09, 2009 | Brother IntelliFAX 560 Plain Paper Fax
    Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
    hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
    Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
    FAX 560 Brothers displays message "Memory Full"
    Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
    Printing a Fax in Memory
    If you have Fax Storage ON for remote retrieval, you can still print a fax in the
    memory when you are at your machine:
    1 Press Function/Set, 8, 4.
    2 Press Start.
    3 Press Stop.
    (See Turning On Fax Storage, page R-2.)
    Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
    Brother Intellifax 2800
    Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
    Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
    BROTHER FAX/TELEPONE T76
    Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
    Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
    Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
    132 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
