Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch Dishwasher leaking
My Bosch dishwasher is 2 years old and I have started noticing a puddle of water at the bottom while it is running. We have looked everywhere and cannot find where the water is coming from.
Any suggestions?
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Posted on Jul 01, 2008
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
KitchenAide Dishwasher KUDS01FL leaks water
i have had mine leak (usually out of the left side) I can see it coming off the black rubber seal that ends about 2/3 of the way down the side. ( I have also replaced the inner seal around the tub- that helped as the bottom of the seal would stick to the door when closed and make a gap for water to come out) I also notice that water and moisture comes out at the top of the dishwasher (then it leaks down the side and front) I have heard of many problems with the latch...and I can push mine closed tighter but it doesnt close completely with just the latch, but enough for the wash cycle to work. also just make sure there are no crumbs or something stuck around the liner. good luck mine has been a lemon and i cant wait to get a different brand.
Jun 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 6802UC dishwasher is leaking water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
264 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
