The connection to the internet is always kicking me out. sometimes without a warning. can this be my modem?
    Scholar:
  • 141 Answers
Hi meow,
that would be your internet service provider. call them up and tell them about your frequent internet disconnection. :)
Posted on Jun 30, 2008
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
Tip
Internet Connection Issue: How to do a Sequential Power Cycle
Most of the time we worry about why our Internet Connection suddenly goes off without warning and when this happen, we find ourselves nowhere to run for help or cramming to call a technical support line ending up paying for a simple support such as a Sequential Power Cycle. <br /> Internet Technology backbone is based on transmission signal. Signals can sometimes "time-out" causing your modem not to detect connection thus kicking your Internet off. This sort of problem is so usual that most people tend to overlook it. That is why I'm writing this tip as sort of a "First-Aid" for non-technical people to patch their Internet "time-out" problems. <br /> <br /> How to do a Sequential Power Cycle: <br /> <ol> <li>Turn off the Computer. (laptop or desktop)</li> <li>Turn off the Router (if you have any). Unplug it off the power supply.</li> <li>Turn off the Modem and make sure to unplug it off the power supply.</li></ol> <br /> Leave the devices off for at least a minute. Then turn them back on sequentially. <br /> <ol> <li>Turn the Modem back on. The modem will do a self test to check if all connections are working. Leave it for at least a minute to initialize.</li> <li>Turn the Router back on. Let it initialize properly and wait at least a minute before going to the next step.</li> <li>Turn the Computer back on. Allow it to fully load all the startup programs and services.</li></ol> <br /> After doing the above steps. Check if you can browse the Internet using your preferred browser. Hope this helps.
on Dec 25, 2010 | Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Ive had this modem for a while now. all of the sudden some lights start blinking and sometimes they dont blink at all and thats when i lose connectivity to my internet. ive try resetting it back to default...
Sounds like the signal level drops too much.
Connect the modem in the first cable from outside (without splitters).
Check the fitting (must be clean and shine, the copper wire).
You could have too much drops with your cable installation. You need to put an amplifier.
Or try to eliminate some splitters and renew the fittings.
Good luck.
Rate my possible solutions. Thanks.
Jul 12, 2011 | Arris SURFboard® SB5101 Cable Modem
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I have a ZyXEL P-660R-D1 router connected to my Linksys Wireless-G 2.4 GHz Broadband router and I'm having a few problems. First, the internet light on my ZyXEL won't light up EVER. I am not sure if that...
First of, unplug your Linksys and go right into your ZyXEL, (you might need to run a cable) Run that way for a while, If your not cut off then it's your router. Do this first and we can go from there.
Dec 22, 2010 | Zyxel Prestige 660R Router (91004397002)
Loss of internet connection
Please google "network magic" from cisco. Get it ... free for a limited time then they want $ or ... keep using the limited version for free.
I use the paid pro version to manage my network and I love it.
The program is easy to use and will perform all the functions you will need to stay on the WWW. Did I mention it is SIMPLE to use yet it is complete and comprehensive. It will help with wireless security too, if that is an issue.
Dec 26, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Internet connection sometimes always failed
your 5200 mobile is come with speed up internet if you have prblms in internet connection speed its problem of sim card company . THANK YOU>
Dec 04, 2008 | Nokia 5200 Cellular Phone
Acitivity light is always off, cannot connect to the internet
Might want to try a new ethernet cable going from your modem to your computer- If that does not fix your problem then I would try connecting through USB.
Sep 28, 2008 | Arris SURFboard SB4200 Modem
Sounds like a switch before the signal gets to your house. Modems usually don't go out intermittently unless they are overheating. Is the modem in a ventilated area where it can get some air? An alternate is to borrow a modem from a friend to test it. Usually one of your niehbors will have the same service and the same modem. I had my surfboard (from comcast) for 5 years and it was solid as a rock, the spotty services was always at the Comcast switches (at the street or the nearest hub.
Hope this helps
Jun 13, 2008 | Arris SURFboard SB5120 Modem
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
