Question about Panasonic Televison & Video
52 inch projection HD
So, what happened is my picture became mixed up with colors and the words warped like an Arch.  You can still see a picture and sound.  What my husband wants to replace is STK clips and resistors... Advice?
  • pmaher Jul 04, 2008
    Yes, Thank you!  My husband ordered the Kit!  He's going to fix it tomorrow, and I'll let you know the results.  He's a Techie so its right up his alley!  ML, Pam
  • Panasonic Master
  • 8,617 Answers
Yes the STK ICs need replacing. Most panasonics use STK392-110 ICs you can replacement ICs and resistors at the following link with instalation instructions with pictures and free shipping. here is the link.
http://servicemanuals.vstore.ca/
Posted on Jun 30, 2008
Hi ,,my problem is one day turning on the tv and it turns itself off ..when i got it back on the color was distorted and theres a color arch thru the picture ...we get a picture but its not aligned ..and...
This would be called a convergence defect. IT is not a real bad repair but it will have to be done by an authorized RCA repair shop. The alignment takes a jig called a chipper checker. Call around your area. WE charge about 250.00 to do this in columbus GA. THat should give you a starting point
Please leave feedback
Feb 21, 2011 | RCA P52926 52" Rear Projection Television
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
"Warped" picture
The convergence power supply board is famous for having issue. You can get parts and free tech support to help isolate whats wrong from www.tvrepairworld.com
Jun 04, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture is warped, colors are off.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. You can get the kit at www.tvrepairworld.com which contains the parts and the CD with instructions its 24.95
Oct 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Mithsubishi HD-1080 rear projection tv 65 picture warps and distorted when first turned on.
sounds like your convergence ICs are getting weak, or the solder may need to be touched up.
Apr 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
