Question about Sansui Audio Players & Recorders
Desperately in need of san0506 setup manual also I have a subwoofer san0669 having a problem setting this up need instructions
3 Suggested Answers
  • 47 Answers
SOURCE: Simplicity 4700 Instruction Manual
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
SOURCE: i need a setup instructions manual
hi,
U can get it from this link.
www.softwaredriverdownload.com/lexmark_x4270_all_in_one_printer_instruction_setup_manual.html
Posted on Jan 16, 2010
I'm looking to connect a Marantz SR5001 to a Subwoofer, and there is currently no soundcoming through the sub.
On the SR series, you should find the setting for this in the setup menu on your remote. It will be easiest if you have a TV connected for video display. On the remote hit Amp -> Menu -> Speaker Setup -> Manual Setup. This should allow you to set the 'Subwoofer' setting to Yes. The subwoofer will need to be plugged in. If the setting cant be changed, try plugging in the Audassey microphone and run the calibration program which should detect the sub if its plugged in.
Jan 25, 2016 | Marantz SR5001
I have a quantum fx rem 115 jumbo universal remote and lost my manual. I'm trying desperately to find the codes for my Toshiba TV. I can't download manuals sadly unless someone emails them. Can...
0834,0183,0291,0829,0154. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 08, 2013 | Televison & Video
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
On my kenwood receiver vr 707... I'm having difficulties in getting any base for subwoofer. I pluged in the "subwoofer pre-out" like it says in the manual but it seems as if there's no power...
hi,
p { margin-bottom: 0.21cm; }
You have to set the subwoofer setting in you system .for that do the following.
1 .For the remote control, press and hold the TUNER key for more than 3 seconds to switch to receiver mode.
  1. Press the SETUP key to enter the SETUP mode and select SETUP SYSTEM using up arrow or down arrow
  2. Select SP SETUP and press the SETUP key again so that the speaker system indication "SP SYSTEM" scrolls across the display.
  3. Press up arrow or down arrow to select OTHERS and press SETUP key
  4. press the up arrow or down arrow to select the SUBW ON and press SETUP key
    exit the setup and try. Is the subwoofer is working or not
ok
Jan 26, 2011 | Kenwood VR-707 Receiver
How to switch on Sub?
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Nov 16, 2009 | Sherwood R-945 Receiver
I need installation manual
its not a subwoofer it is a midrange speaker. all you do is connect your outputs from the radio to the crossover then connect both the tweeter and midrange to the outputs on the crossover. it is called a component set.
Oct 01, 2009 | Quantum Audio QP500C Car Subwoofer
Subwoofer amplifier
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Apr 21, 2009 | Audio Players & Recorders
How to conect my ipod to car stereo KDC-MP205
Here's a link to the instruction manual -->LINK<-- .
It goes into detail to setup the aux input.
Plug iPod into front 3.5mm jack on front and follow the setup instructions.
Regards
Philip
Jul 22, 2008 | Kenwood Car Audio & Video
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
43 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
