Question about ASUS A8N-VM Motherboard
Is my CPU fried
ASUS said my motherboard was fried does that mean that my cpu is also toast? What happened is that the chipset fan burned out which has incapacitated the mobo.
Oh, also mymothernoard is an A8N-SLI not a VM.
THanks
    Sergeant:
    Champion:
  • 417 Answers
IF *********** BOARD IT FRIED DOESN'T MEAN UR CPU IS IF YOU CPU IS INTEL MOST LIKELY YOUR CPU IS FINE IF AMD THEIRS A 40% CHANCE IT IS FRIED - I WORK WITH COMPUTERS AND IVE SEEN IT ALL BEFORE SO I KNOW WHAT IM TALKING ABOUT
Posted on Jul 02, 2008
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
ASUS Motherboard M2N68-LA (False) "cpu fan has failed" If I press the F2 on the keyboard, bypass this failure and computer keep running well.
U'L LDAMAGE YOUR MOTHERBOARD AND THE CPU TURN IT OFF AND UNPLUG ALL CABLES OPEN THE CAS COVER AND CHECK THE CPU FA N IS MOVING OR NOT IF NOT THEN CLEAN THE FAN AND CHECK THE FAN CABLE IF IT STILL NOT MOVING CHANGE THE HEATSINK INCLUDIN THE FAN DA VN
Jun 13, 2010 | Intel D915GAG Socket 775 Motherboard -...
Need to know chipset voltages ,found cpu and memory volts but no chipset info. thanks
get your solution from this link
1) i4memory.com/f56/chipset-voltage-1443/
Oct 02, 2009 | ASUS M3A78 Motherboard
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Monitor not coming ON
The monitor is not able to detect any video signal from the motherboard, that means your pc is not starting up. Try cleaning the RAM first. Then clear the CMOS and try to start ur computer again
Nov 24, 2008 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Asus p5p800s
It could be that you have a damaged power supply which took out your motherboard. When turning it on, what beeps did it make?
Sep 17, 2008 | ASUS P5P800S Motherboard
ASUS cpu fan required
CPU fan is supplied with the processor it self you need to contact your processor company
it you are talking abt the Casing fan then just get an ordinary casing from from a hardware shop
Dec 13, 2007 | Zalman Tech Zalman North Bridge Chipset...
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
M7VIG-400 NOT POWERING ON
possible cause: 1.low supply of voltage try checking your Power Supply Unit(PSU). try to swap with a different good PSU. 2.Defective/burned Motherboard, check for any bloated Capacitors or burned chips...
Sep 09, 2007 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
ASUS A8N-VM Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
