Question about SanDisk Sansa Clip MP3 Player
Sansa wont turn on.
Hello, My sansa won't turn on. I think the battery is loose. how do i fix that?
  • 8,596 Answers
The clip on the back comes off, and you can remove, reinsert the battery.
Posted on Jun 30, 2008
My DELL Insiron is not charging
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead.
2. the battery bay is loose
3. the battery itself is loose
Hope this helps...
Nov 17, 2012 | Dell Inspiron 1000 Notebook
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Battery won't Charge
Hope this helps
Nov 04, 2012 | HP Computers & Internet
Won't turn on
Please give some more details.
I suppose it's the problem that your Sansa e250 MP3 Player won't turn on.
You could turn to Sansa official support.
Jan 03, 2012 | SanDisk Sansa e250 MP3 Player
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Sansa View screen is messed up
ok i just had the white screen issue after some squezzing thinking it might be something loose i randomly decided to turn it on wile holding the left button and to my surprise im greeted by the word SANSA and not a white screen. hope this can help someone
Apr 08, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
No battery icon
so... does it connect to the computer?... then wanna have some fun? :p well i think you should use ubuntu you can get it here: http://www.ubuntu.com/getubuntu/download
then you boot with the live cd and a fast guide how to go into diffrent modes here :
manufracting mode hold (on) and push center button while turning your sansa on..
recovery mode hold(on) and push rec buttin while turns player on
in rec mode it should come a 15 or 16 mb partition showing on the computer in there it is some files
when using ubuntu download :
http://chrisjs.com/PP5022.mi4
http://daniel.haxx.se/sansa/e200/BL_SD_boardSupportSD.rom
then replace the original files with those and then emty the trash and unmount the player and unconnect it it should uppgrade system on sansa auto... when finished exit sansa and boot in normal mode hold (off) and don´t push any buttons while start the sansa if it won´t work email me on skrap94@hotmail.com wite sansa problem in beginning of message i will reply as fast as possibel if u having troubel.
Feb 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 battery trouble
You might want to buy a new battery. I belive you could probably get a new battery at walmart and best buy.
Oct 20, 2007 | SanDisk Sansa e260 MP3 Player
Changing batteries
Hello, I've actually had the same problem with mine. What happens with mine is the spring becomes loose or bent and needs to be (gently) pried back into it's original position. Hope this is of some help, Jenna
Jan 15, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
