Question about Lands Phones
I own an i730 Motorola. Bought it a few years ago when I was with Southern Linc. I have never used it for anything other than the walkie-talkie. My Nextel i710 Motorola transmit button stopped working so the phone is no good. I took the sim card from the Nextel phone and put it in the Southern Linc phone. It says "Enter Special Code" What do I do to make the Southern Linc phone functional with the Nextel Sim card ?
    President:
  • 357 Answers
Hi, Welcome to FixYa
This document is also available in PDF format (this PDF has higher qualify images and a password and is not free. It requires purchase, with your purchase, you will receive the HEX file for Raptor Pro that's mentioned in this web page) for easier viewing and printing.
RSS Carrier + iDENPro
Phone Power: On
i-DEN phones are made by Motorola. They use SIM cards and look like GSM phones, but they are not GSM. The most popular iDEN network in the US is Nextel (now with Sprint) and Boost (owned by Nextel)
For most i-Den phones, use the RSS Carrier to put the phone RSS-SIM mode. Then use iDEN Pro.
It is recommended that you use the USB cable for Motorola iDEN phone when using RSS carrier and iDEN pro. Pay attention, the iDEN cable is very similar to the Motorola V600 cable, but a bit wider. So be careful not to confuse them.
RSS Carrier is useful for reading either the six-digit or four-digit phone or user security code. However, the actual unlocking of the Service Provider lock is done with iDEN Pro software.
Once you connected the phone, some times it will prompt you to install the driver, just follow the instruction and install it automatically. If it does not work, try to manually install the driver from the directory, which the Motorola RSS is located.
Assuming the driver has been successfully installed already. You should open the RSS Carrier software, click on File and Read Phone. This should put the phone into RSS-SIM mode.
Now you can exit RSS. Open the iDEN Pro software, and wait for it to detect the phone. Then click on Script | Open Script. Open a file under the iDEN Pro directory called “command3.txt” and then go to Script | Run Script. The phone should restart after the script is finished. Now test with a different SIM card.
Raptor Pro For a long time, Raptor Pro was not updated and stopped supporting any phones newer than the i405. However, recently the Raptor Pro’s hex file has been updated to support almost all i-DEN phones on the market. To unlock, i-DEN i880, i885, Raptor Pro (keep in mind the Hex File can be found under C:\Program Files\Raptor Pro\Hex File) has to be updated to support this type of phone. Make sure a SIM card is insider the phone and the phone should be on and ask for a special subsidy code. Then you should connect the phone using serial cable on COM1 and run Raptor Pro. It will take few minutes and give you the unlock code. It should be the first one. After getting your unlock code, try to put it into your phone with a different SIM.
Tip Some times when a person insert a different SIM and has entered the incorrect unlock code more than few times, the phone will show “Enter Special Code, Please Wait” or “Contact Service Provider”. In this case, you need to wait up to one hour for the phone to allow you to enter the unlock code again.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helped you.
Posted on Jun 30, 2008
  • 2,794 Answers
All you have to do is contact your cell phone provider and give them the numbers off of your phone (the IMEI number and the code) located under the battery. Sometimes you can retrieve the information off of the phone as well. You could also try getting a hold of Motorola to do an unlock as well. It takes anywhere from a few days to a week to do. As long as you have all of the information from your Nextel phone.
  • Lands Phones Master
  • 6,487 Answers
To understand What Unlocking is, we have to understand the forms of locks...
Passcode: (4 digits)
What it is:
The passcode lock is a 4 digit lock that shows up every time you power the phone on. This lock is normally set by the owner.
It exists at:
Menu > Settings > Change Password > Unlock Code
Who needs it unlocked:
-Anyone who forgot their 4 digit unlock code, or anyone who acquired a phone that has this lock enabled.
Default: 0000
Security: (6 digits)
What it is:
Its main function is primarily to lock up options like Master Reset.
-Normally, no one. LOL
-Probably just someone who forgot their code
Default: 000000
And the worst...
Subsidy
What it is:
This is a Carrier Specific Lock. This is the mother of all locks, and about 90% of all unlocking we do here. This lock is so bad, it varies in ROM versions. The purpose of this lock is to keep the owner on 1 specific Carrier.
For example, if you own an i450 you'll notice if you attempt to put a NEXTEL SIM inside of it, it won't work. It'll ask you for this unlock code. Thats because they designed the i450 to work for only Boost. The Boost phones are locked against Nextel. However, Nextel Phones aren't locked against Boost.
-Dealers
-Anyone who owns a BOOST and needs a NEXTEL\iDEN CHIP
-Anyone who has a phone and needs to use another iDEN service provider (southernlinc, telus, etc)
Default: NONE
Hope that helps........
I want to unlock my motorola clutch i465 to use with any carrier. It is currently locked into the Southern Linc network which is pretty much over in these parts
There are many methods for unlocking mobile phones, that is through software, codes,calculator,some tools , hardware and all ,but in that codes are best one, because it is easy to understand the instructions and enter into your mobile ,just give your IMEI number, country & network lock , then you can get the unlock code..........
For the good place to get the unlock code for your mobile phone, Just visit this site www.superunlockcodes.com/motorola-clutch-i465/rs12wp9, It provides the step by step instructions and simple methods for unlocking mobile phones at a safe way...........
Aug 11, 2011 | Motorola Mobility Clutch i465 Cell Phone
I need a manual to learn how to work my phone
User guides vary slightly by carrier, but the basic features should all be the same.
Sprint/Nextel Guide Boost Mobile Guide Southern Linc Guide
Jun 10, 2011 | Motorola Mobility i1 Smartphone
How to unlock the motorola i730
Use the following steps to unlock your mobile....
1 - Switch ON your Motorola I730 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
And get the unlock code here theunlockarena.com
Sep 01, 2010 | Motorola Mobility FOR MOTOROLA NEXTEL I860...
I just bought a clutch i465 went putting in my sim card from my i730 it ask`s my for a code.what do i do? i dont have any info on what code to put in it.
may be the sim is asking for the password which u used in i730. other wise read the user manual there will be the passwored
Mar 20, 2010 | Motorola Mobility Clutch i465 Cell Phone
I have a t-mobile simcard and is asking me for a lock code
If you are attempting to use a T-Mobile SIM card in a Nextel Motorola i730 mobile phone it will NOT work.
T-Mobile phones operate off of a GSM network. The Nextel i730 operates on an iDEN network.
The phone you have can never be compatible with the network you are trying to use it on.
Sep 07, 2009 | Motorola Mobility Naztech Nextel Iden...
I cannot get the sim card out of my motorola i730
Hello, please open this link: http://www.wonderhowto.com/how-to/video/how-to-operate-the-motorola-nextel-i730-mobile-phone-250239/view/
On that page click on SIM card Portability under Phone Feature...
If you are unable to remove the SIM card... then try to use a Tweezers.
Jul 14, 2009 | Motorola Mobility Naztech Nextel Iden...
Inside screen white
How can I contact Motorola for support questions?
Canada Customer Support Numbers On Line and Telephone Order Inquires 1-800-461-4575
Broadband Technical Support 1-877-466-8646
Business/Government Two Way 1-866-948-5200
Cellular 1-800-461-4575
iDEN 1-800-453-0920
Messaging 1-800-461-4575
US Customer Support Numbers Broadband 1-877-466-8646
US Cellular 1-800-331-6456
US Paging 1-800-548-9954
Consumer Two-Way 1-800-353-2729
Business/Government Two-Way 1-800-353-2729
iDEN (Nextel/Southern LINC/Telus) 1-800-453-0920
Consumer Modems 1-800-221-4380
Professional Two-Way Radios Spirit 1-800-448-6686
Oct 22, 2008 | Motorola Mobility RAZR V3
Motorola Special Code Number
motorola i305, carrier was nextel. i try to put my att. sim card in the i305, but didn't work. Now the phone saids it needs a special code.  Does any body know the code and does this unlock the i305 that way i could use my att cincular sim card in it?
Jun 30, 2008 | Lands Phones
Lands Phones Logo
442 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
