SOURCE: my shedder wont shedded
It could be you have a broken or stripped gear. If you can disassemble the rig and look at the drive mechanim, this should tell you what is happening. Availability of parts would be questionable. check the motor- is it turning, or are the bearings dried out and sticking? Check the mechanim for freedom of movement.
SOURCE: The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
SOURCE: Teeth are bent and paper/material from credit card is jammed
One teeth are bent in this and other similar lower end units, they can't be fixed. Return it to the place you purchased it from and see if they'll be gracious enough to replace it. But these machines are not intended to handle a lot of the heavy guage stuff people put in them. The cost of a replacement cutter unit, if one can be located, would be more expensive than buying a new one.
SOURCE: Our Aurora AS1712X paper shredder is jammed in a c...
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
SOURCE: I have an Aurora as662c paper shredder, I have a
There are 5 screws that you need to remove, 1 of them is hidden beneath a white sticker that says void warranty if removed.
I was having the same problem with my shredder. I called
customer service; I was informed it was the gears on the inside of my shredder.
My shredder is no longer under warranty. However, she is mailing me out the
part I need for a small fee. Their customer service number is 1-800-327-8508 in
the USA and international only 1-310-793-5650. I do hope this help you!
