Question about Whirlpool LER5636P Electric Dryer
Whirlpool drier has no heat and won't shut off . . .
Both the heating element and timer appear to gone out at the same time. Are they somehow related? ( Attempting to dry clothes, the drier ran all night long, and in the morning was still running with no heat ). Can you recommend something.
  • 481 Answers
It was most likely caused by the timer not turning off and burning out the heating element or a temperature switch or tripping one side of the circuit breaker in the house. it really needs to be checked out by a professional. unless it is old then you might want to replace it.
  • best case scenario:
  • the breaker has tripped (turn it off then back on to find out)
  • the TIMER MOTOR is the only problem <$30
If the timer itself is bad then it will cost a lot more.
Posted on Jun 30, 2008
Whirlpool drier not drying and wont shut off
Bad timer. Your timer controls when it shuts off also the heating.
Mar 23, 2015 | Whirlpool Dryers
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
LHE 5800: timer not working and not heating up
Have the timer checked and the heating element.
Jan 26, 2013 | Whirlpool Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
Jul 31, 2012 | Dryers
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
