Question about Compaq Presario M2000 Notebook
Lost my Dog, Wife, Truck, Wireless
Hi!
As long as I've had this laptop, I've stayed away from its little on/off button for the wireless connection. Never had a problem with it before now. The wireless adapter simply vanished. The external wireless button does nothing. Nothing appears in Windows's Device Manager - no card, no unknown device, no nothing. It's just gone. All traces of it except (I assume) the internal, physical device itself.
Kinda tempted to suspect that it's a hardware problem, but I'm hoping that there's a few last things I can try with it before I take it to the blacksmith for a good retempering and firing in the forge...
...thanks, experts.
  • vwnut88 Dec 12, 2008
    i have the same problem, i left my compaq presario f500 on one night as i had to go to wotk, and when i came back it was off, and my wireless wouldn't work, the button would not come on. i tried to go to control panel, and check the setting, but i wouldn't let me access it, when i double clicked on it, it loads and then stops. my pc doesn't recognize its their.
    please help
    Genius:
  • 2,028 Answers
The wireless card will be under a panel on the bottom of the machine, Clean and check the connections on the card. Reinstall it and reboot the computer, if it doesn't see it then do a hardware search. If it still doesn't find it, then download the drivers for it at Compaq's support site. Sometimes a driver glitch will cause the card to go dormant and the machine goes blind, by reloading the drivers fresh the machine will get past the glitch and see the card again. Almost like DUH there it is. If it still has issues, then the card has failed. You can find them relatively cheap on Ebay. Keep in mind that the card doesn't have to be the original card that is in your machine, it just needs to have the proper drivers. If you purchase a card that came from a different make or model, you can find the drivers at driverguide.com by the card make and model.
Posted on Jun 30, 2008
Hi , ive just recently purchased a faulty compaq m2000 laptop from ebay, this also had the same problem with the wireless connection. if you look at the underside of the laptop undo the cover for the ram then you'll be able to get to the screw to the wireless card cover. remove the wireless card and try re-seating the it and check the cables (black & grey) on it as thay can sometimes come loose.
Hope this helps.
Neil
Write about the PetSafe stay+play wireless dog fence?
According to me, one of the best wireless dog fence is a PetSafe stay+play wireless fence. If you prefer outdoor camping, travelling then this portable dog fence system is perfect for you. You can take this dog fence anywhere without doing set up for the whole day.
Nov 03, 2017 | Saws
I have just bought a second hand acer aspire 5610z and I can't get on line !. I can when I connect the cable from the modem/router? to the laptop but not wireless.. It runs vista if that is any help.I'm...
There is a wireless button on your keybord platform area. Have you tried pushing it? It should have a little upright stick with commas on either side on the button (to look like a wireless signsl tower)?
Jul 31, 2010 | Acer Aspire 5610 Notebook
My wireless mouse takes battries with short
hi,
I've got a Microsoft wireless Intellimouse and the batteries in that last for months - and it's on all the time. My wife bought a no-name mini wireless mouse and found the batteries last a couple of weeks.
The difference? My mouse takes two AA batteries, hers takes one AAA. So if you change mice(?) look for one that takes two AA batteries and stay away from any that don't.
Sep 24, 2009 | HP Wireless Optical Mouse
Wireless card works. says cant find wireless
There's a little switch on the right hand side below the keyboard...
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
Cant get wife to connect is the wireless icon
hi
no the wifi stay blinking on activity, but the wireless connection on the laptop has to stay on
1. first have you tried with the ISP if you need any Proxy settings or specific IP address.
2. also check with the ISP if you need any specific DNS server settings
3. if the above two are given or not required but the router still does not give out connections then try this
instead of connecting the cable from the Modem to the slot named INTERNET try connecting it in one of the out going slots (numbered 1,2,3,4) and now connect the other systems as usual.
cheers
PS: if this has been any bit useful pls rate it, thanks
Jun 27, 2009 | Belkin Computers & Internet
Wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | Gateway M305CRV Notebook
Wireless connection
First you must sure that your wireless card is working
Second confirm your wireless setup is right.
Then reset your wireless account. Or your laptop battery cant supply the power to your wireless card, check the metal connection.
Oct 28, 2008 | HP Compaq nx6110 Notebook
Wireless problem
Are u staying at the same place when u plug and unplug the AC power outlet?
Jun 03, 2007 | Acer Aspire 5003WLMi Notebook
Compaq Presario M2000 Notebook Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
