Question about GE Refrigerators
Water is collecting in the bottom of the refrigerator.
  • 1,462 Answers
Assuming this is a conventional fridge.
the drain in the centre of the gulley on the back wall is blocked. push something flexible down it and follow with a small jug of water to make sure it flows away.
good idea to put a small jug of dilute bleach down the drain now and again to prevent blockage
Posted on Jun 30, 2008
I have a whirlpool designer 20 refrigerator, it is collecting water at the bottom. What is going on? How can I fix it?
In the freezer, under the cooling coil, is a drain pan that collects water after the coil defrosts. The drain opening from this pan is probably plugged with debris. If you can find the drain line under neath the refrigerator and blow through it, this will usually clear it.
Oct 09, 2014 | Whirlpool Refrigerators
Where does evaporation water collect?
Defrost water goes into the drain-pan below the refrigerator and utilizes the air that goes across the condenser coils to EVAPORATE into the air. There is no collection of water :-)
Aug 17, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water collecting on floor under the refrigerator
The evaporator pan in the bottom of you refrigerator may be out of place, damaged or missing. there also may be a problem with the drain tube being bent and not dripping into the pan. It is also possible that the drain tube could be clogged and water could be collecting in the bottom of the refrigerator and spilling out too.
Jan 10, 2014 | Refrigerators
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water is collecting at the bottom. Where is it
Refrigerators have a defrost water drain that carries water produced during the defrost cycle to the bottom of the refrigerator where it flows into a catch pan. The water is then evaporated by heat from the compressor and refrigerant coils.
Something is likely blocked in your drain system. There is usually a catch basin in the rear of the refrigerator behind the inside lining. From that catch basin, water flows into tubes which usually run down the back of the refrigerator. The drain in the catch basin may be stopped up, or the tube itself could be blocked.
Oct 15, 2009 | Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
