LG 50PB2DR Plasma TV HDD will initialise itself regularly when either beginning recording, or accessing the recorded TV menu, thus deleting all recorded TV stored on hard drive.
SOURCE: I have a lg Model 50PC1DRA-UA Plasma TV-DVR
I would suggest reform the hard drive. That means you will lose all your data... should be an option in the menu..
Posted on Jan 29, 2008
  • 286 Answers
SOURCE: i have an lg 50pt8
Check your owners manual and see if there is a way to format the hard drive. If so, format it and try it again.
If not, or if you can't get past the hdd error, check your owners manual and see what type of hard drive it takes. Go to your local computer store, buy one and install it in your TV. This SHOULD stop the error message, and allow you to format the new drive using your TV's menu structure. Again, check the owners manual for formatting instructions.
If you are an experimental type of person, you can install the tv hard drive in an external hard drive case, plug it into your computer and try to get it running.
Finally, if it turns out to be some kind of proprietary hard drive you may have to check with LG to purchase a replacement.
Posted on May 07, 2008
SOURCE: LG DVD/HDD recorder RH2T80 hard disc problem
I've got the new firmware. Email me @ damian.hocking@gmail.com
It'a 7MB file, just copy it and play & you should be ok.
Posted on Jan 20, 2009
SOURCE: LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
Posted on Jul 24, 2010
SOURCE: how do i access the Hard Drive out of a Wharfedale DVDR24HD160F 160GB HDD DVD Recorder
hmm...similar problem here. i've taken the hdd out and plugged it in to the ide port inside my pc. The problem is it's the wrong file system. Your pc will not see it. It is however just a normal hdd so you can re-partition it and give it a new file systm ie ntfs but you lose all the data :(. that's as far as i've got, hope it helps someone.
Posted on Sep 21, 2010
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
All saved recordings have disappeared from menu. system has reset itself and now all recording in the HDD play menu have disapperaed. They must still be on the HDD because nothing else has been...
dissambling and taking the hard drive out of the dvr will most likely void the warrenty how it is possible.
once the hard drive is removed you may be able to plug it into your PC and gain access to the files on the hard drive. These how ever may be specially encoded and protected files that you cant open.
-you PVR may have also done a hard reset and formatted the hard drive. This would delete all the files on the PVR.
-unlike tapes, erasing a hard drive does not require you to record over it. just because nothing else has been recorded does not mean your data is still there. sorry.
Mar 01, 2011 | Pioneer DVR-720H-S DVD/HDD Recorder
LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
Jul 06, 2010 | LG Electronics 42 in. LCD Tv
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
LG DR4812W DVD RECORDER DISC INITIALISE
hi!we have read your problem.please dont worry, every problem hasa solution.all you have to do is buy a dvd lens cleaner and clean the4 dvd lens since dust particles on lens will delay the processes.but make sure you are not using detergents or plain water to clean it and never touch the lens with bare hands hope your problem is tackled.have a nice day.
May 23, 2009 | LG DR787T DVD Recorder
LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Feb 15, 2008 | LG RH177 DVD Recorder/HDD Recorder
HDD locked?
Have you tried resetting the recorder to it's default settings either through the menu or by pressing and holding the power button while unplugging it. After unplugging leave it of for a few minutes and then turn it on again.
Jan 15, 2008 | LG RH266 Recorder
Connection problems.
Must be connected by now I guess :)
Dec 14, 2007 | LG RH177 DVD Recorder/HDD Recorder
Strange...but i have the exact tv...and I was able to delete the demo..but never had a problem with it popping up every 15 minutes.
Oct 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
