Pyro therm heat exchanger model wh 701382 London Heat Machine (7 Tube) recently bought a new replacement module equivalent to the existing heat exchanger for the fireplace, but having difficulties in connecting onto the heat exchange box when switched on, it made a lot of noise (before, no noise heard) Could not find a cueent distributor for the brand, that we could call from Vancouver, British Columbia.
Boba
  • 64 Answers
SOURCE: unlocked RAZR wont connect to the internet
If you have had the unit re-flashed then this has problably deleted all your internet settings, if you contact your service/network provider in BC then I am sure they will be able to give you the settings so you can enter them.
Posted on Mar 30, 2006
Therinnaiguy
  • 1420 Answers
SOURCE: weathermaker 8000 58zav115
The technician sould have replaced the circuit board with part number CESO11057-02 which contains a diagnostic LED that will blink out a code when a fault is senced. If not we have to diagnose the hard and costly way, test each circuit.
There are only a limited number of reasons why the blower would stop running, one being a bad blower relay and another being a overheating of the motor inself causing it to shut off on internal overheat. The relay is part of your circuit board and the overheat is inside the motor, both of which you had replaced. Has anyone checked for a restricted air filter or supply/return restriction? Loose wire?
I'm guessing now. Good Luck and let us know what you find.
Posted on Jan 23, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman furnace model #GPO 125_4 REV 8 Installed 6/2/2002
Have you measured the temperature in the suppy plenum? Should be 140 to 160 max. If hotter, you have a blockage in the ductwork or vents closed. If within spec, bad circuit board.
Posted on Jun 10, 2008
koolbreezes
  • 540 Answers
SOURCE: Ruud UBHC-17AOONFA heat exchanger
Instead of air , it uses water to extract heat and send it thru the tubings.
Posted on Sep 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Water filters
Cuisinart does sell them. You will have to call the Canadian line or go to www.cuisinart.ca
Posted on Dec 09, 2008
Jeep patriot no heat
fan blows?
engine reaches and holds 180F or more , normal engine temp?
(use a IR pyro gun to measure it)
ever go a cooling system flush, if not the heater core could be packed full of junk.
id the dampers fail , its not in heat mode.
check the dampers after checking engine heat.
it only takes 2 things to make any water to air heat exchanger to work.
hot water
and actual air flow.
check for hot water first (engine coolant)
Feb 05, 2014 | 2009 Jeep Patriot
My bocsh 830es water heater will be running normal then will kick into a A3 mode no more hot water
Check for a green wire near the top right of your machine. It would loop back to itself with a little black heat shrink on it. This should be far away from the heat exchanger. if its near it, I would recommend pulling it out of the wire clips, and relocating it to behind the control unit on the right side of the machine. Keep it away from heat....its a resistor, and will pop random A3 codes if the heat increases its resistance. Reset your code and you'll be good to go.
Jan 01, 2014 | Bosch Therm 830 ES NG Internal Tankless...
Raypak RP2100 Heat Exchanger Disassembly
new heat exchange should come with hardware
Aug 05, 2012 | Raypak Pool & Spa
My laars mighty therm keeps igniting on and over constanty, whats the problem
There is a problem with flame rectification. This could be caused by a dirty flame sensor, poor ground to burner, faulty ignition module, improper venting, inadequate combustion air, dirty burners, or clogged heat exchanger.
Jan 26, 2011 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Water is flowing out of the exhaust for the heat exchanger. The tank is overfilling. we have checked all the pipes going into and out of the heater and they are clear.
The heat exchanger under the fan is leaking and filling the heaters lower cavity with water. It can not get out so eventually it backs all the way up to and out of the fan. The heat exchanger is an expensive repair but they do not 'fix' well due to the curved pipes. You can try a radiator shop but most likely you will end up buying a new exchanger.
John
Aug 19, 2010 | Sta Rite MaxETherm Pool Heaters 200K BTU...
Lately my four years old Laars Mini Therm makes whining noise when it runs; especially at night when everything is quiet. Please sugest what most likely the cause ... Thanks
Quite possibly a partially plugged heat exchanger either water side or gas side. The gas side would be soot deposits on the heat exchanger preventing the proper flow of comubstion gases from flowing out the vent, the water side would be scale build up on the inside of the heat exchanger.
Jul 06, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
My bunn coffee maker leaks water out the coffee maker.
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Aug 11, 2008 | Bunn BT10B Coffee Maker
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
