Question about Samsung Cameras
Samsung S630 low battery life
I use Ni-mh rechargeable batteries in my camera and only get about 5 pictures before the camera beeps and says i have low battery. i've went into the menu and turned the settings down as suggested in other solutions and it didnt help. what can i do?
3 Suggested Answers
SOURCE: battery life is to short!!!!!
Its the camera, I have the same one and it eats batteries like nothing. I suggest rechargables.
Posted on Feb 20, 2008
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
Need a charger for a Camera
Hey annah99,
The rechargeable batteries that came with your camera should be able to be replaced with any rechargeable Ni-MH AA batteries, and our Best Buy™ stores carry these batteries as well as a charger to go with them. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 26, 2008 | Samsung Digimax S630 Digital Camera
Low battery display
go to your local walmart and but a set of nimh rechargeable batteries and let them charg when done charging install them in to you camra then hit the menu button go to the setup display and scrool down to the battery type and choose Ni-MH this will save you battery life from 5-15 min to 5-6 hrs of life.
May 06, 2008 | Samsung Digimax D53 Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
CAMERA NOT WORKING
For the Rechargeable batteries1.gif (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
Jan 06, 2008 | Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Cameras lens stuck out and wont turn on
eject the camera battery and clean with pin your battery tip in your camera after that turn on your camera .
hope its helpful for you
Oct 16, 2007 | Samsung Digimax S630 Digital Camera
Battery life expectancy
Olympus Ni-MH batteries will last approximately 60 to 80 images and can be recharged about 500 times. The Olympus CR-V3 long-life lithium batteries provide power up to 2 times that of Ni-MH batteries. The CR-V3 long-life lithium batteries are NOT rechargeable.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Battery
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Cameras Logo
198 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
