Question about RCA RCU403 Remote Control
Auto code search didn't work.
I need codes for sylvannia tv
Call sylvania or down load a free manual pdf for your model
Posted on Jun 30, 2008
Need a code for my tv its a tecnicolour by rca none of the rca codes would work and the auto code search didnt work either :
I have a different model of RCA but had the same problem, try this: Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Oct 03, 2016 | RCA RCR504BR 4-DEVICE PALM-SIZED UNIVERSAL...
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
How do you use your dish remote to power on a sylvannia tv
You will need to program the remote using the correct remote code for your model television. If you still have the manual for the television, the remote code should be located in there. If it's not there or you don't have the manual you can look up the codes online. There is no guarantee that the codes provided will work but most companies stick with a group of codes and use them in all of their products. Some good sources for remote codes would be:
http://www.hifi-remote.com/ofa/codes-tv.shtml
or
http://kbase.x10.com/wiki/Universal_Remote_Code_List
You can also just google your tv model using "remote codes" as a search field and something should come up.
Dish provides a decent tutorial on how to program the codes into their remotes here:
http://www.digitaldish.com/how-to-program-dish-remote.htm
Give the codes a try and hopefully you'll be able to control everything with one remote.
Also, if you find that you are having difficulty getting the codes to work, you can always purchase a "learning remote" which will allow you to program each remote key individually using the remotes to each individual device. I bought one of these:
http://www.amazon.com/PS3-Blu-Link-Universal-Remote-Control-Pc/dp/B002LARYGA/ref=sr_1_3?ie=UTF8&qid=1309193347&sr=8-3
and programmed it to control my Sony television, Xbox 360, PS3 and surround sound system. The instructions are pretty straightforward and it made my life a lot simpler.
Jun 27, 2011 | Televison & Video
Lost manual need to know how to set remote to tv
You need 2 things to program your remote to your TV, the programming instructions and the correct code for your TV brand. There are 4 different methods for programming the remote, which are explained in the following videos:
Direct code search:
http://audiovox2.info/videos/rca_acc/new_intro.html
Auto code search:
http://audiovox2.info/videos/rca_acc/auto_code.html
Brand code search:
http://audiovox2.info/videos/rca_acc/brand_code.html
Manual code entry:
http://audiovox2.info/videos/rca_acc/manual_code.html
Sorry, but there is too much information to list it all here so it's much easier if you watch the videos. You will need to have Adobe Flash Player installed on your PC to view them:
http://get.adobe.com/flash/
Please note, your remote is fairly old and if you are requesting this information in order to program your remote to a NEW TV, the code searches and manual code entry are NOT guaranteed to work.
If the code searches don't work, it's unlikely that your remote can be used with your TV, but if you need to use the manual code entry method, you can find the codes for all TV brands here:
http://rcaaccessories.com/remotefinder/?sku=RCR311B&productType=TV
Regards,
BElectric
Nov 18, 2010 | RCA RCR311B Remote Control
Need a code
ok i dont have the code but the remote can find it on its own... here are the instructions
auto code search:
1. turn the component that you want the remote to operate
2 press and hold the CODE SEARCH key until the indicator light illuminates. Then Release the CODE SEARCH key
3 press and realse the component key that corresponds to the component you want the remote to operate. the indicator light blinks once
4 aim the remote to the component and press the ON/OFF key once. the remote automatically sends every code for the specifed component one at a time witha 3 second delay between each code. keep the remote aimed at teh component throughout the process.
5 as soon as the component turns off you must press the ENTER key immedialtely so the remote stores the correct code. if you dont press ENTER within 3 seconds the remote will send the next code in the list and you have to start over from step 2.
hope this helps you... it worked with mine. i found the manual but not the code list.
Jan 09, 2010 | RCA RCU300WBL Remote Control
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
Need code for sylvania lc195slx
hi! i have a couple of codes here for your sylvania tv just try them 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161 hope it would help! goodluck!!!!
Sep 02, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
RCA RCU403 Remote Control Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
