Question about E-Machines eMachines Desktop PC
E-machines T5026 comes on goes only to the "e" screen
It says i can press for bios settings, does not work, i tried to restart with boot disc, does nothing, has my computer crashed, or is it just stuck, i turned it off for 24 hrs before restarting this last time, still same results
    Novelist:
    Scholar:
  • 141 Answers
Some bios use F5 for a one time boot sequence. If lucky you'll get this option to choose cd rom as first boot device.
You can remove the Cmos battery for about 3 min. It is the small round watch looking type battery on the motherboard. This may reset all defaults in case of hardware/software conflicts.
If nothing still try a new Hard Drive.
YES I would say you have crashed because it is "just stuck". But this doesn't mean your computer is fried.
Try these things if your want let me know what happens and I'll try to help from there.
There is a recovery option with the xp installation disk that will fix your master boot and boot record on Hard Drive. If your interested let me know!
Posted on Jul 01, 2008
How do I get past the blue screen? Computer has been stuck on this for weeks. It has been rebooted, restarted, unplugged, still doesn't get past blue screen.
First unplug your machine and plug it back in and turn it on while its booting up you should see a message to press the F2 key to enter the BIOS. press that key, you will only have a couple of seconds to press it. Look for an option called First Boot Device, Boot Sequence, or something similar; press the arrow keys on your keyboard to select this field and then press Enter (You may have to select Advanced Options or another submenu to find it.) In the resulting screen, select CDROM/DVD and then press the Esc key until you return to the main BIOS screen. Follow the onscreen instructions to save your new settings and exit BIOS setup. Insert the installation disc (you need an installation disc of the operating system, if you dont have one you can find one on amazon, but if you needed to buy one you should consider upgrading to windows 7(more like vista) or Windows 8 (not really like vista)) once the disc is inserted restart the computer and follow the on-screen instructions
Nov 07, 2014 | HP Pavilion Computers & Internet
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
Err1err3
There are several issues that can cause this err1err3 issue. It could be a bad hard disc (or a bad wire between the drive and the motherboard), an incorrect BIOS setting for the SATA hard drive or a problem with the master boot record (MBR). Make sure that there is no disc in the CD drive and disconnect any external storage devices (flash drive). Your computer may be trying to boot from a non-bootable disc.
To check the BIOS setting, turn off the computer and turn it back on. Press F10 continuously to access the BIOS on an HP computer. Some HP computers use F2 or F6. There should be a splash screen that tells you which to use. (If you see the error again, try this step again. It's easy to not have the key press noticed between the POST and the attempt to boot the computer.) Once in the BIOS, go to the Advanced Settings tab (one to the right) and go down to the SATA1 controller option. (Try AHCI.) Then press F10 to save and exit. (Note this isn't part of the BIOS on all HP machines - it does work for some.) See if there is a Diagnostics tab in the BIOS and try running the hard drive test.
Get an hard drive testing utility (ISO) and burn it to CD on another computer. You can set the first boot location when you go into the BIOS as above. With the bootable CD in the drive, restart the computer. (Some machines let you set the one-time boot location by pressing F12 on start up; as with entering the BIOS, it's easy to miss the timing. Just repeat the attempt.)
If the disc tests as good, you can try to repair the MBR. Use a repair tool or an OS install disc for your version of Vista (Home Premium). Boot from the CD as above. With the install disc, follow the on- screen directions and select the Repair option. You will need to enter the Command line mode. You'll need to enter Bootrec with the correct option. For more information, see the following document: http://support.microsoft.com/kb/927392 .
If you possibly can, remove the drive from your current computer before trying the repair. Use a USB/IDE/SATA adapter and another computer, see if the data on the disc can be copied to make a back up. This will work if the disc is still good. (It will also indicate if the cable was the problem if the disc failed the diagnostic tests.)
I hope this helps.
Apr 16, 2012 | HP Pavilion Computers & Internet
System registry problem says its missing a fill from there and it wont reboot my windows vista ultimate disc but the sony vaio laptop comes with windows premium..
If your laptop isn't booting from your Windows Disc, it is not because of corrupt registry. It is because the BIOS settings.
1. Restart your laptop.
2. The screen where the logo of manufacturer is displayed press and hold F10.
In most BIOS it would lead you to the BIOS setup screen.
3. Find anything which sounds similar to Boot Order. (Different BIOS use different names).
4. Select the Optical Media Drive to be the first one to be checked for bootable media.
5. Save the settings and restart.
For very detailed instructions, follow this link.
http://www.hiren.info/pages/bios-boot-cdrom
Jun 03, 2011 | Computers & Internet
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
Trying to recover from acer restore cds but keeps coming up with the above eror number and telling me to restart computer
Hello
Can you read the that recovery disk in another computer/laptop? If yes,put the CD into the tray When you boot your system hit f12, then select your USB cdrom, and it should boot then.
If no,you have to check the BIOS settings to ensure that "CD-ROM Drive" is set as the first boot device, otherwise the PC will ignore the disc.
press F2 at the acer splash-screen during the boot process, or when you see "Press F2 to enter setup" at the bottom of the screen.
On the main BIOS screen there is a menu along the top.
Use arrow key to highlight 'BOOT' in the menu bar.
Now you see "Boot Priority Order"
Yours probably has "IDE 0" as first boot device,
and "CD/DVD as second boot device.
The first boot device (IDE 0) is already highlighted.
Press 'F6' to swap them round, so that first boot device is
"CD/DVD"
Now press 'F10'
Highlight "YES" at the prompt (may already be highlighted) and press <Enter>
PC will reboot, this time from the CD/DVD drive first.
You can leave the BIOS set like that permanently so you don't have to go through all that process again next time, just don't leave a bootable disc in the drive unless you really want to boot from it.
Apr 12, 2011 | Computers & Internet
I have bought new boot disc or restore disc but it runs one cd then blue screen says discs wont work.it tells me to alt ctrl and delete then shows message that ntldr is missing.I know my compaq hp stores...
for setup the bios usually by pressing delete at first screen appear
or for some type motherboard is pressing F2 at first screen appear
after you at setup bios go to boot menu
the go to select boot menu and chose boot from cd for the first boot
then press f10 to save the bios setting and computer will restart
after restart isert your boot disc and if it ask to press any key to boot from cd press any key
then follow the instruction for install the operating system
Mar 04, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Blue Screen of Death, after Windows Logo. Wants to check Fat32
Does it Start in Safe Mode? Press F8 key or whatever gets you into the screen that lets you choose how to start Windows.Choose Safe Mode.Further help can be tried if you can get it to start in safe mode.Sounds like power loss while writting to C drive.Good Luck.
Sep 05, 2009 | Acer Aspire 3000 Notebook
When I boot I get as far as a screen that
Have you tried pressing F8 at boot time and booting in "safe mode". Then you can think of a solution.
Jul 27, 2009 | E-Machines eMachines Desktop PC
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
