Hard Drive Errors / Bad Performance
Here are the error codes. What do they mean?
An error was detected on device \Device\Harddisk0\D during a paging operation.
A parity error was detected on \Device\Ide\IdePort2.
The driver detected a controller error on \Device\Harddisk0\D.
  • 79 Answers
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
How to repair
When drives start to develop bad blocks/bad sectors it's time to replace the drive. See if it is still under warranty and replace it.
Sep 02, 2012 | Infortrend EONSTOR A16F-G2430 - HARD DRIVE...
Ahci port0 device error
This indicates the hard drive is bad and close to failure, backup all critical files, test the hardware for errors using windows tools, it can repair files and attempt repairs on bad sectors.
May 28, 2012 | ASUS Computers & Internet
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Inspiron 8500 laptop (80GB) intermittant boot failure
Hi
Thank you for your query
If there is a clicking noise inside then the hard drive is on the way out, the arm that reads the data is knocking against the plates, thus the noise
I would recommned that you back your data as soon as possible as the drive will eventually fail
Please can i ask that you leave feedback and vote if this has been useful
Feb 12, 2010 | Dell Hard Drive for Inspiron 8500 and 8600...
Getting an error message 05 bad sectors detected
1.Your device or hard drive is needing replacement.
2. You may need to format and reload the data.
Bad sector errors are from usage on most mp3 devices.
Jan 06, 2010 | Argosy HV358T Audio/Video MP4/MP3/...
An error was detected on device \Device\Harddisk2
run dskchk /p /r
What's the pagesize file size?
Check proper seating of cabling as well.
More about chkdsk at:
https://technet.microsoft.com/en-us/library/bb491051.aspx
Aug 02, 2017 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Hard Drive Freezing PC
Back up your hard drive asap, it it's starting to fail. Purchase a SSD type hard drive as a replacement. Good luck.
Nov 24, 2017 | Computers & Internet
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
