How do I hook it up SMC
Smc switch 5 port
  • filup Sep 12, 2008
    I purchased the model 01517 at a garage sale and would like to use it to network my printer. Is that possible ?
Huh!?
Posted on Jul 03, 2008
HOW DO I RESET A SMC 10/100 TO FACTORY DEFULT
Remove the power cord from the back of the switch.
Remove all cables from the front panel ports.
Connect port 1 to port 2 on the front panel using a standard patch cable.
Reconnect power to the switch.
Wait at least 40 seconds before disconnecting the patch cable between port 1 and port 2.
After the above is completed, the password will be "smcadmin" and the switch IP will revert to 192.168.2.10
Mar 01, 2013 | SMC Tigerswitch 24-port 10/100 Switch...
Cannot log into the SMC8024l2 switch via ethernet or console and after resetting to factory defaults still cannot ping the device at the default IP Address or the IP address it was set up on.
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
Apr 02, 2011 | SMC EZ Switch SMC-8024L2 24-Port Gigabit
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Problem with SMC EtherEZ Hub
you can use as many as you have number of ports. example
one port goes to your broadband router, one goes to your computer, one can go to your laptop PC, one can go to your wireless AP if you have one , etcc......
Mar 23, 2009 | SMC EtherEZ Networking Hub
SMC ethernz problem
Typically you will connect your router to port 1 of the switch. Unless you have a port that is labeled WAN or Uplink. Then you would use that.
Daisy chain is when you have multiple switches connected to eachother. So it would be router to port 1 computers on ports 2-15, port 16 would connect to port 1 on another switch, and so on.
Jul 20, 2008 | SMC EtherEZ Networking Hub
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
