Question about VeriFone TRANZ 380 Transaction System (X2, 256K) (P03600173)
"Programming Err 0"
"Progaming Err 0" will not leave the terminal and the terminal will not do anything.
Bobbi
  • Anonymous Nov 29, 2008
    my terminal has the same problem, may mean dead memory battery.
The error message "Programming Err 0" means that the terminal memory has been corrupted. The only way forward is to acknowledge the situation and reload the terminal application.
If you press the [1] and [FUNC/ENTER] key at the same time, oten the message will go away. However, you will have a terminal with no programming in it. You will need to call your processing company and get a new load.
David
Prairie Trail Software, Inc.
Providing applications and hosting solutions for Tranz terminals and web based transactions
Posted on Jul 01, 2008
Can I program the car to recognixe the key fob.
1996 Roadmaster
  1. Locate the programming connector located in the LH trunk. Trim may have to be pulled back to access programming connector. ( Connector has black/white wires leading up to it and it is not connected to anything.)
  2. Jump programming connector terminals. Leave terminals jumped unitl step 6.
  3. System should now lock and unlock doors to indicate programming mode has been entered.
  4. Press any button on keyless remote once. System should now lock and unlock doors, indicating successful programming of keyless remote.
  5. Repeat step 4 for additional remote or other existing keyless remote. NOTE: A maximum of only two Keyless Remotes can be programmed.
  6. Remove programming connector jumper wire to exit programming mode.
  7. Test remote(s).
Oct 19, 2015 | 1996 Buick Roadmaster
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
Progaming tv with universl remote control
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 09, 2014 | Toshiba 40RV525R 40 in. HDTV
How to resolve CODEPLUG ERR on Motorola PTX760
Your radio needs to be reprogrammed or repaired. This type of error can occur for no reason, or during an interruption in programming. Check your programming/test set-up. Do not try to reprogram using the same codeplug (saved version of programming) as previously used, as it may be corrupt. If you cannot get the error to clear with a fresh programming, the radio will need to go to Motorola to have the error cleared.
Best regards.
Apr 12, 2013 | Laird EXL42MX * Motorola PTX760 Motorola...
After I replace a new battery in the key,hawcan I reset the antitheft system on mu 2008 Lancer
Not reset reprogram right. To do that follow the instructions below.
1. Locate the Data Port under drivers side dashboard usually located to the right of steering column.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port terminals 1 and 4 with a
suitable jumper wire, leave the jumper wire connected throughout the programming procedure. Make sure you
know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors will
automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successful
programming, the door will lock and unlock once.
6. Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing each
programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition.
Oct 10, 2012 | 2008 Mitsubishi Lancer GTS CVT Sedan
Bc142xl progaming channel
The operating manual for the BC142XLT is on my "impossible to find" list, but scanners in the 14x series are nearly identical in programming and operation, so this manual will walk you through the programming steps
http://www.box.net/shared/it6eozctkb
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Feb 11, 2011 | Uniden BC244CLT Base Scanner
NEED TO REEPROGRAMING A REMOTE CONTROL FOR A MALIBU 1998 HOW '?
1. Make sure ignition is in the OFF position.
2. Locate the Programming Connector in the trunk (center of rear shelf). It is a plastic connector with
two wires leading up to it. The connector is not plugged into anything. You may have to pull back
trim to access the connector.
3. The programming connector should have two terminals. Connect both terminals with a suitable
jumper wire. The Keyless Entry Module will lock then unlock all the door lock motors once. Make
sure the terminals remain connected throughout the programming procedure.
4. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for at least 15
seconds or until the vehicle automatically locks and unlocks the door locks. Your new remote has
been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each transmitter to be programmed. Do not remove jumper wire in
between programming of transmitters.
6. Remove the jumper wire from the Keyless Programming Connector.
Dec 15, 2009 | 1998 Chevrolet Malibu
How to program a new remote
1. Locate the Data Port under drivers side dashboard usually located to the right of steering column. obd-1.jpg 2. Insert keys in ignition and leave in the OFF position.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
How to reset the stereo system
To reset remove your negative battery terminal and leave disconnected for a few moments, re-connect negative terminal and you are reset.
Hope this helps
Jun 27, 2008 | 2004 Hyundai XG350
Televison & Video Logo
1,666 people viewed this question
Top VeriFone Televison & Video Experts
AliennoisE
Bosse Photos
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
