Question about Marvin 1210 Floor / Box Fan
Fan blades Motor runs properly but fan blades don't turn
  • Anonymous Aug 25, 2008
    I have from QVC model 1220 stand up box from about 3-4 years ago...blades do not go around...motor works...I called your 800 service number and it is not valid! Help..760 200-1861
    Sergeant:
  • 234 Answers
Their is problem in push! change your fan push! then the wings are rotate
Posted on Jun 30, 2008
Why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Jun 27, 2014 | Kitchen Ranges
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
Fan starts when i open door
follow this test and use the multimeter and fix it. God bless you
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
My Fan is somehow loose and gets jammed. I don't see how the fan metal bracket fastens to anything and therefore is sort of floating loose and the blade keeps rubbing up against the plastic...
Fan should not be rubbing up against anything. I don't think the fan is secured properly to the motor shaft. Tighten down the metal clip that holds the fan onto the shaft. Make sure it's not back too far.
Jul 14, 2011 | Ecoquest Breeze AT Living Air Purifier
Sometimes get a loud screeching noise from the condenser fan motor. Also seems to be loudr than usual. Motor part no. is:S070. Can a "do it yourself" guy replace the unit?
If this is wall/window unit, you can do it but it can be tricky. the fan in window units usually has 2
shafts on either side , it drives fan for both the condenser and evaporator. You basically have to pull the top off, loosen set screw on both blades, remove some screws to move back condenser coil(gently, don't kink tubing) similar process on evap side. Then mount new fan motor, wire it in put fan blades back on in proper position, reassemble unit, test run on bench.
Jun 26, 2011 | Heating & Cooling
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Nov 18, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Marvin 1210 Floor / Box Fan Logo
192 people viewed this question
Top Marvin Dryers Experts
Are you a Marvin Dryer Expert? Answer questions, earn points and help others
