Question about Whirlpool GS563LXS Kitchen Range
Whirlpool model GS563LXSQ 0 oven won't stay lit
My Whirlpool oven model GS563LXSQ 0 wont stay lit. It came with the house we bought in 2006 (brand new).
  • pfinan Apr 05, 2009
    oven lites heats to set temp. goes off and won't come back on to maintain temp.
4 Suggested Answers
  • 12 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Posted on Feb 20, 2009
  • 43 Answers
SOURCE: My Whirlpool gas range model #GS563LXSQ during
possible overheating.high limit may be tripping as a safety.may want to check thermostat,or high limit safety.
Posted on Oct 10, 2009
  • 254 Answers
SOURCE: cook top works but oven isnt. igniter clicks, oven
sounds like ur ignitor or glow bar is bad... replace that bake ignitor usually a sgr403 if round ignitor, or a 12400035 if flat style these are two kinda generic ,, if u want the whirlpool part u will pay double these parts are the same thing just made by diefferetn manufacture ,, u can see pics of these parts at repairclinic.com hope this helps
Posted on Jan 31, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
My oven will turn on but won't stay lit (
The light may be loose, or one of the micro switches are going.
Apr 03, 2012 | Whirlpool Microwave Ovens
Cook top works but oven isnt. igniter clicks, oven smells gas, but its not burning. i have a whirlpool model gs563lxsq. thank you
Jan 30, 2010 | Whirlpool Kitchen Ranges
My Whirlpool gas range model #GS563LXSQ during cooking will lockup and shut down, what causes this?
Oct 09, 2009 | Whirlpool Kitchen Ranges
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Jun 09, 2009 | Whirlpool Microwave Ovens
Gas oven won"t stay lit
Feb 20, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Open Questions:
This range has worked fine for over 3 years. We use the oven a lot, the broiler not often. Last evening after using the stove for several things, then the broiler very briefly, both of them stopped working. The "Preheat" display comes on, then you hear the loud click (which I assume is an electronic valve), then instead of hearing the burners ignite, you get another loud click, no ignition. The stovetop burners all work. -------------------------------------------------------------------------------- Following up on my own question here, I found a document online titled Whirlpool Gas Range Direct Spark Ignition System, which applies to this range. I got a multimeter, followed the directions in the document. Seemingly this procedure indicated this Spark Ignition Module, which controls both the broiler igniter and the bake (oven) igniter, was bad. Then, just to be thorough, I tested the double solenoid which is part of the electronic Gas Distribution Valve which runs gas to the bake burners and the broil burners. The broil terminal was dead. This manual says if one is dead, neither will operate. The solenoid is tested when it is disconnected from the oven. The solenoid IS connected when you test the spark ignition system. So, my tester showed two problems, and for either one, the manual says replace it. But, it's hard to believe both parts went bad at the same timel So, I hope the gas distribution valve solenoid is the whole problem. Anyway, I going to replace that first, and see what happens. Does that make sense?
Feb 28, 2017 | Whirlpool GS563LXS Kitchen Range
Whirlpool GS563LXS Kitchen Range Logo
266 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
