General Electric Microwave Oven Logo
A
Anonymous Posted on Dec 11, 2010
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2719
Points
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE owner's manuals and installation instructions here.
Can't remove old spacemaker from wall
My GE spacesave microwave oven isn't heating. It is about 6 years old but I only installed it and started using it 4 days ago.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhgj
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
2answers
Trying to remove ge spacesaver microwave but do not know how it mounts
2answers
How do you remove old 'GE Spacemaker' microwave oven ?
Ge spacemaker microwave removeal
Try lifting up and then out while gently moving the oven down and then up again.
Hope that fixed your dilemma.
Worldvet
1helpful
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
