Question about Garmin nuvi 200W GPS Receiver
I need a system for tractor trailer trucks & can't find it. Please help.
Posted on Dec 30, 2008
What is makin the trailer brakes not release on a 1999 sterling tractor truck?
when you release the brakes (pushing in yellow and red release buttons) ,tp1and tp2 do the rods in the chambers retract in to cans, ? where is the air going ? you may want to just crack 1 line at a time to see and follow air as it moves from tractor to trailer , no chance glad hands are reversed ? are your slack adjusters moving?are air tanks full 120-150 psi ?what happens when you manually retract slacks,that should cause rod to go into can , are brakes in very good condition ?(lining,springs,"S" cams and bushings drums ), you said you replaced valves does that include quick release valves (QR1) and relay valves ? did you also change anti compounding valve ?what happens when you push on brakes and dash valves are released ,where is the air going , do you think there's any problems with ABS if equipped ? if you manually retract brakes (using lock out devices or keys ) do brakes release , PLEASE don't get mad when you read this I'm just giving things to think of , I have done 100's of truck and trailer brakes , and it sounds like you did every thing and then some to try to get it to work . I really hope I helped you . Woody.
Sep 04, 2014 | Cars & Trucks
Tractor manual
see if this links helps you, you will need serial number, year, and plate location. Hope this helps
Oct 19, 2013 | Garden
Daftar nama suku cadang Nissan terano
Kami menjual Spare Part (Suku Cadang) dan Komponen (Component) khusus untuk Truk (Heavy Duty Truck merek Nissan Diesel, Hino, Volvo, dll meliputi model Bus, Cargo Truck, Trailer, Semi Trailer, Low Bed Truck , Logging Truck, Mixer Truck, Dump Truck dan Tank Truck. Untuk bagian Engine, Transmission, Transfer, Cover & Disc Clutch, Steering, Axle, Differential, Compressor, Pump, Electric,dll. Kunjungi web kami untuk detailnya. Informasi lebih jelas, silahkan hubungi :
Mobile : 081382119888 & 081288639888
Phone : 021-44455887 & 44455889
Fax : 021-85904666
Email :
Website : http://www.Tractor-Truck.Com
Jul 30, 2012 | Mazda Cars & Trucks
When I tow with my car the left blinker doesn't work on the trailer. There is a 7 pin round plug on the car, with a flat adapter to the flat pin on the trailer. I have had the same problem with at...
Hello Carol, The 7 way is for use with a brake controller and/or a trailer that has electric brakes. The 4 way flat is a basic trailer plug connector.
Connect as follows:
Green wire- Connects to the vehicles right turn wire harness & provides brake light and right turn signal on trailer.
Yellow wire- Connects to vehicles left turn wire & powers brake light & Left turn signal on trailer
White wire- Ground
Brown Wire- Tail/ marker/ license plate lights
The Blue, Red & Purple wires on the 7 way will not be used on the adapter, those are for brakes.
I hope this information is helpful.
Sep 18, 2011 | Honda Accord Cars & Trucks
Pig tail on chevy truck works on one trailer. When I connect to other trailer lights work but when you apply brake the tail lights go out on trailer. Blowing my mind. What is wrong? Do I need to rewire...
go on line and do a search for trailer wire diagrams and you will see and know what colors are used. they are black brown yellow and green and each one controls a different task.
Oct 16, 2010 | Dixie Winn Tractor Trailer Truck (The...
Describe number/color sequence for vehicle towing trailer connection
when you buy a trailer connection plug the number/color is in the packet , if you go to an auto accessories shop you might be able to have a look at a trailer plug there & write all the imformation you need down & do it that way.....hope this helps.....cheers
Aug 04, 2010 | 1998 Chevrolet Tahoe
SemiTrailer Wiring when I turn on my left turn signal all lights blink.
sounds like if its a 2 filiment bulb(1156) one of the filiments is touching the other and back feeding the signal,start by removing all signal bulbs and replace each with a new one as a test,also reground all grounds,if the signal cant find reference ground it will take the next path to find it,if this doesnt work then possibly you have wires in the frame bare and touching
Mar 18, 2010 | 2004 Dodge Ram 1500
What battery does a 05' Volvo 670 tractor use?
Regular dry cell one's try and stay around 1000 cold cranking amps.. don't use deep cell batteries. (Marine Batteries) this will not last as long and if you mix deep cycle with regular batteries it will harm the eletric system. and kill your regular battieries faster...
Oct 13, 2009 | Volvo 670 Tractor With Dry Van Trailer
Tractor has been sitting for awhile,transmission
old oil in motor & may be too level too low aswell
condensation or moisture has probably got to the cylinder bores & bearings etc!
my guess would be it has locked up !
try lubricting the cylinders & rocking the cranckshaft as this can sometimes free them up
but i doubt if it will be in any condition to use even if you get it freed up & maybe even started again!!
best bet would be to strip it down & recondition it!
Cheers Rob
Jul 28, 2009 | Star Manufacturing International Tractor...
Garmin nuvi 200W GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
