Question about JVC TH-C3 System
DVD plays in black and white
I hope someone can help me, I put my hand down on the remote and now when I play a DVD its in blank and white. HELP
  • Glimpant Jul 20, 2008
    My System only plays dvd in black and white any one help please
  • 151 Answers
Go into dvd player settings and into video settings as i think you have set this to s-video if this hase happened change it to video or RGB if you can.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 30, 2008
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
My daughter has been playing with the remote control on her Technika tv/DVD combo and now it will only play dvd's in black and white can anyone please help x
Hi, First check that the colour is set to about half way and that you can actually adjust it. Then check the colour system when playing a dvd, set it to PAL or NTSC or whatever the DVD recommends or in the menu. Is it still black n white when you watch just the Television programs?
Sep 21, 2012 | Televison & Video
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Aug 06, 2012 | Televison & Video
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Jul 10, 2009 | Panasonic DVD-RV31 DVD Player
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
DVD has no color
Check your remote for a button that says, Progressive Scan, or PSCAN. Push it and then play your movie. Should work. Worked for ours. Good luck.
Sep 15, 2007 | Televison & Video
Tv/dvd combo only plays dvd's in black and white
Finally figured this out. On your remote push tv menu until you get to function. You should automatically be under col.sys. change this to NTSC. Took me awhile to get remote to work here, ended up pushing in the middle of the red vol +,- bar on the right of the remote. Couldn't find the right button according to the directions on the screen. DVD is now in color!! If you are not already on the option to change col.sys, use the red channel up down bar on the left of the remote.
Feb 22, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Open Questions:
JVC TH-C3 System Logo
95 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
