Question about Canon i860 InkJet Photo Printer
One color My i860 started printing only orange so I did the cleaning and now it prints only magenta. If I print a document it will print black. But any kind of color it prints magenta.
    Scholar:
  • 49 Answers
Yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Error code:P21 and P8
try to go to your printers and faxes it is located in the start menu.
Apr 03, 2014 | Konica Minolta Minolta Bizhub C253 Copier
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
My Canon I860 has stopped printing any of the colors. When printing a color picture, the printing takes an extra long time and then only the black colors are printed.
To solve the problem follow the mentioned stages bellow:
1.Click start, then printer and fax icon
2.click maintenance tab, then clic ink cartridge setting
3. Select auto dedection or Black and colour cartridge.
Then cloge all.
Thank you.
Aug 27, 2010 | Canon i860 InkJet Photo Printer
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
My canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
182 people viewed this question
old marine
old marine
