Are we able to get the Binding machine blades sharpened. We have an Ibico, Ibimatic-No 315468. Have had for about 5 years. Thanks
  • ezpz Jun 30, 2008
    Thanks for that. Great quick reply
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
This product is now manufactured by GBC (General Binding Corp, part of Acco) and was replaced by the CombBind C150 - just FYI. The lower-end machines such as this seem to run in the range of $200 USD.
I have never heard of sharpening these "blades", as they are actually punches, and there are likely some 20 small, individual "blades" that are part of the system. You might check with a local dealer or office supply partner, to see if they know of anyone who could or would perform the service and what they might charge for it. I believe that if you could find someone to do it, it would cost more than it would to simply replace the machine. There does not appear to be a way to replace the punch mechanism (die / strip usually) in these models.
An example of a machine with interchangeable dies is located at: http://www.factory-express.com/Binding_Machines/WireBindingMachines/GBC-TL2900/GBC-wirebind-TL2900.html.
Obviously, this is a much higher-level (expensive) machine than the one you have here. But this is an example of the interchange concept, and associated costs.
So, this is a rather long way of saying, and trying to explain why I recommend that, you check with a local dealer perhaps, but plan to replace the machine. If it lasted you this long, the same level of machine should last just as well, and $40 US a year isn't too bad!
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Posted on Jun 30, 2008
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Can blades be sharpened
Hedge trimmer blades are really NOT worth sharpening, after you get done paying for the tech rate/ labor, you're better off just replacing them. It would take forever to sharpen each of the 2 blades with all those teeth... Don't waste your money, get new blades.
Small engine tech of 15 years.
Aug 26, 2015 | Garden
What kinds of pencil sharpners are there?
There are many kinds of pencil sharpeners that have been developed through the years.
The most common ones, the manual sharpners, can be of the following kinds:
Mechanical sharpeners: a portable variety, usually small and in the shape of a rectangular prism. The blade inside rotates around the pencil, sharpening it. The shavings emerge through a slot.
Blade sharpeners: small and portable, hold replaceable shaving razor blades or permanently fitted blades. They work similarly to knives, but in a more convenient and safe way.
Cylindrical cutters: larger variety, stationary, powered by a crank. One hand holds the pencil, the other turns the crank.
Another common pencil sharpener found often in offices is the electric sharpener. It works on the same principle as the manual sharpener, but the blade rotates quickly thanks to an electric motor, either powered by batteries or plugged into the electrical system.
There are still people, mainly artists, that sharpen their pencils with a knife.
Oct 06, 2013 | Office Equipment & Supplies
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Hi, used a blade sharpener for my a2 horse clipper blades and they are still blunt. Do i sharpen between the teeth
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
Nov 18, 2009 | Makita 9820 - 2 Blade Sharpener
Ibico binding machine
I have sold some Ibico machines, depends on the model some are only designed to punch a few sheets such as 6 to 10 booklets. Need the model.
Jun 24, 2008 | Office Equipment & Supplies
Ibico 080s
ACCO Brands Corporation owns General Binding Corporation (GBC). GBC offers products under numerous brands, including Ibico. Ibico's owner's address appears to be in Switzerland
From GBC's sparse Ibico's homepage:
"Contact Us
Where can you buy Ibico Products, fill in your information and the products that you are interested in and we will send you information on the nearest Ibico dealer. "
I'd suggest just going to that page (link here) and filling out the contact info and including the specific information about the model found on this page (namely the product ID num)
.... i could be way off... but it is all i could find on google =)
Jan 04, 2008 | Office Equipment & Supplies
Ibico Binding Machine User Manual/Instructions
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
Kaye.Eldridge@acco.com
Jerry Quinn
Sep 28, 2007 | Office Equipment & Supplies
343 people viewed this question
jasbo
jasbo
