Question about Refrigerators
Kenmore 57072791 side-by-side 1998 not cooling
My unit will not cool at all.  Lights come on. All fans seem to work. Compressor clicks and gets hot, but coils do not get cold in freezer nor warm underneath.  When timer gets to it it seems to go through the defrost cycle (though it definitely does not need it.)  Coils inside not frozen over. Is there a way to test the starter relay? (two wires - looks clean)  Can you tell me a course of action?
  • asphaltdance Jul 17, 2008
    Kenmore 57072791 1998 not cooling in either freezer or fridge. Lights on. Strip between doors room temp. Coils feel a bit cooler than room. Fan runs, cannot tell if compressor is running. Visual inspection of front bottom and rear revealed nothing that looked untoward, but how would I know?
    asphalt dancer
Oceti
  • 51 Answers
SOURCE: Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Posted on Dec 09, 2007
  • 116 Answers
SOURCE: Maytag Refrigerator MSD2756DE Coils are icing up
Please disconnect power from your refrigerator before attempting the following! You will likely need an adaptive defrost board for your refrigerator. The defrost thermostat and heater is only available as an assembly and can be checked while the unit is freezing by checking the resistance with a multimeter. there should be some resistance to the heater assembly but not infinite. If the resistance is high then the heater assembly will have to be replaced. Your model has an adaptive defrost board located in the upper right hand back portion of the control panel in the refrigerator side. This cover is removed by placing your fingers in the 2 indentations at the back of the cover one on the left and one on the right and pulling down and forward. Once the cover is off there are a couple of screws directly above the lights which have to be removed and a couple of hex head screws behind the number faceplate and on the back wall near the water filter. Once these are removed the whole housing will come down the board is at the far back right. It will either be a bare circuit board or a small white box. Just unplug it and replace it with a new one. This will correct 99% of the defrost problems on this line of refrigerators.
Posted on Mar 11, 2007
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
peyton32034
  • 410 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Posted on Dec 18, 2007
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore 596.50692001 side by side stopped working last night. The fan was not working at first. It eventually came back on and the unit seems not to be cooling. The compressor was a little hot???. The...
replace your fan,cause is no cooling the compressor,and check if the compressor didnt burn out to.if my info was of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side, fan on, lights on, compressor hot, no cool.
You probably have a bad overload/relay on the compressor . The piece which plugs onto the compressor . Or a bad fan which cools the compressor (condensor fan motor ). Also check the coils to make sure they are clean . Would need the first 3 numbers before the ones you gave , to be able to give you the part number for the o/r .
Jul 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refrigerator not cooling
No you don't need to change the compressor you need to change that fan and you need to change the start relay overload and capacitor that goes to the compressor. What is the model number of your refrigerator so I can look up your parts
Apr 02, 2017 | Kenmore Refrigerators
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Refigerator not working properly
the compressor is out of coolant/freon.u should not run it if the compressor is too hot to touch
Aug 02, 2008 | Kenmore Elite 21086
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
