Question about Western Digital Caviar (wd800lb) 80 GB Hard Drive
Drive has power but fails to come on
Computer does not recognize drive- is not in bios
  • 407 Answers
Hi if try bios setting then setup it..
Open your hdd Drive change your jumper .....restart your pc put in Any OS Xp Driver...press ok enter 5 times if it boot then format & setup it....
Posted on Jun 30, 2008
Bios does not see secondary hdd
If you are trying to boot from this drive you have to go into bios and change the boot order.
Jun 30, 2014 | Seagate Barracuda 7200.7 160 GB Hard Drive
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Blue light on runs, but pc doesnt see it
Has the drive been used previously? Possibly on a Mac or Linux machine? If so then Windows may be having a problem recognizing the file system the drive is set up with. Try connecting the drive to the PC, turning off your PC and then turning it on while tapping the Del key. This should bring you to the BIOS where you can have a look around (mostly in the Boot menu) to see if the BIOS can recognize the drive. If the BIOS can see it but Windows can't, it's most likely a problem with the file system. Bring the drive to any Windows or Linux based machine (or make your own Ubuntu Live CD and do it yourself) and reformat the drive to either FAT32 or NTFS (NTFS being the best choice). Windows should have no problem picking up the drive then.
If the BIOS doesn't recognize the drive, bring the drive to another computer and test there. It may be that the power is going to the drive but either not enough to start the hard drive spinning, or that the drive itself has failed. Either way, it's pretty much dead.
Don't forget that most external hard drives and the likes come with pretty long warranties (lifetime in some cases) and you should always contact the manufacturer to find out if it can be replaced or repaired free of charge.
Apr 02, 2011 | Verbatim (R) Wallet Drive(TM) USB Portable...
My Barracuda 7200.7 200GB drive failed. The computer does not recognize that the drive is attached. I can hear it power up but then nothing. No clicking or other noise indicating that the heads are moving....
Try connecting it to another sata port on ypu motherboard or try using another sata cable. If still same problem go to the BIOS if that drive is detected properly. You should see there the model number and the capacity, if its not there then the hard drive has a problem, have it replaced.
Oct 11, 2010 | Seagate Barracuda 7200.7 200 GB Hard Drive
Harddisk fail! but BIOS recognize that as Maxtor .
Is this a primary HDD?
have you checked the jumper?
You can also try to reseat the HDD cable
Feb 22, 2010 | Maxtor Hard Drive
My hard drive which is model dk23eb-40 is not being recognized by my computer at all. not in the bios or nothing. is there something else i can do or is it gone completely
If you can try it in another computer, as the _only_ device connected to the "data" ribbon-cable, and it still fails to be detected, then it's gone, gone, gone.
Jan 16, 2010 | Hitachi TravelStar DK23EB Series DK23EB-40...
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
USB ports on my laptop and others wont recognize my 320GB Passpor
ok
go to your computer bios setup .
U can go to bios with "del" or F@ oe any key for enter in bios setup then go to usb configuration then set high speed and legacy 2.0 enabled then save alls ettings .
May 03, 2009 | Seagate Snow Translucent...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Western Digital Caviar (wd800lb) 80 GB Hard Drive Logo
70 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
joecoolvette
joecoolvette
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
