Question about Motorola Mobility RAZR V3
Blank screen power on blank screen can make and receive phone calls
  • 4 more comments
  • tnight20 Sep 16, 2008
    I'm useing my cell to text or just to look at the time and out of the blue the screen on my razr will just go blank. the phone still "works" but as far as texting gos you ever try doing it blind? well it sucks!
  • Anonymous Oct 09, 2008
    well my cell phone went blank and it wouldnt let me see whos calling me it wouldn't not even let me text no more and now i cant do nothing with my phone only talk
  • cjhope51 Oct 14, 2008
    Screen would go black/blank,in-comig/out-going calls still worked..Tried removing battary and sim cleaned all contact points for above. That has fixed it in the past. Now not so.
  • Anonymous Oct 20, 2008
    Nokia 6086, about one year old, now has a blank screen. Can sometimes receive calls. The day before the blank screen, the menu screen had other written screens superimosed over the menu, so double screen words over other screen words. Couldn't read any of them.
    The next day, screen went to all blue, and cannot get menu. Took out battery, tried everything, then called NOKIA. They didn't say they'd seen this problem, but it is the second NOKIA 6086 I've had and the other one was defective after 2 months. Going to try another phone. My SAMSUNG
    lasted for years and years, great phone, but I wanted new technology.
  • Anonymous Feb 06, 2009
    i have a RAZR and one day i turned it on and the screen is all white. Can't text any more...only call.
  • Morflathen May 04, 2009
    My screen is blank. Usually, it starts up normal and works fine, but if it falls too far, gets set down too hard, or even if I move it too fast, the phone restarts itself and the screen is blank. It normally resolves itself, but lately the screen has been going black for longer and longer. It went blank today, and it has stayed that way so far. Halp!
    PS:
    There is a new problem with it that is tied to this one. When I start my phone while the screen is blank, it will play half of the start-up noise, then play one of my ringtones, which only stops playing when the ringtone is over. Halp again!
    New Friend:
    Problem Solver:
  • 8 Answers
Power on blank screen
Posted on Oct 09, 2008
    Problem Solver:
  • 16 Answers
Yea the flexband is damaged......need to be replaced
Posted on Sep 16, 2008
    Brigadier General:
  • 7,752 Answers
You need to have the flexcable replaced.
Posted on Jul 02, 2008
SOURCE:
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
paudritsh
SOURCE: Outside and inside screen is "black", but still "glows" when powered on?
If you have an SD card, remove and reinstall it. Worked for me.
Posted on Aug 22, 2008
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Posted on Dec 14, 2008
SOURCE: kyocera oyster screen blank
That worked for me, thank you!!
Posted on Feb 13, 2009
myjosh007
  • 530 Answers
SOURCE: motorola razor v9 blank screen.
Friend, thats LCD problem.the flex connector is cut or interface is broken. you can replace that one. if not the LCD is damage or broken so you need to replace the LCD. thts the only problem nothing else for sure.good luck
Posted on Jun 26, 2009
Lg km900 blank screen during an incoming call -
There is a little rectangle shape thing next to the lg logo on the top of the fone screen. If this is blocked by screen protector it will cause the phone to blank of during calls. Its a power saver that blanks the phone when its near your face. Try it. Take off the screen protector & make a call. Then place your finger over the little thing & the screen goes blank. Just cut a lil space in the screen protector & that will fix the problem
Jul 15, 2010 | LG KM900 Arena Cell Phone
My phone is switching on with blank scream
When the phone turns on with the blank screen, can you receive or make calls?
If you can receive and make calls, the fault should be from the screen. Maybe it is not well connected to the board or the screen is bad.
But if you cannot receive or make calls, then I think your phone has a virus. The virus might have corrupted the phone software files, thereby, not allow the phone boot. In this case, you need to flash the phone.
Best wishes.
Dec 30, 2009 | Sony Ericsson K850i Mobile Phone
Screen is blank. can't turn on the handphone
There could be a lot of reasons that would make your phone screen blank.
Maybe the screen is bad, or maybe the flex that connects the phone board and the screen has worn out or maybe your phone virus has made the phone corrupt.
To figure out if it is a virus(corrupt) problem or not. Turn on the phone and use another phone line to call your number, if it rings, then the phone is not corrupt, and the other way round if it does ring.
While the screen is blank and you could still receive a call, then it is either the flex is bad or the screen itself is bad.
To figure out the main fault, I would advice that you take it to a phone expert in your area to diagnose the problem.
I wish you the best of luck.
Dec 21, 2009 | Nokia N95 Cellular Phone
Phone switches on but screen is blank
blank screen
if the phone can make out going call or receive call
maybe the problem come from lcd or the flex cable/ribbon inside the phone.it may come from upper board too.
if the phone blank screen and not responding any key pressed. it may come from the software.
note : broken upper board can make fault on software.cause the phone will detected as K700 on third party tool like setool, after replace the upper board it will detected back as w850.
Sep 23, 2009 | Sony Ericsson W850i Cellular Phone
Blank Screen
I think the your screen may have given up due to long use or due to miosture. This may be fixed by changing the LCD sreen from your mobile's authorized dealer.
Jun 01, 2009 | Sanyo Katana Eclipse X Cell Phone
Screen is blank
rsshoe - the lcd need to be replaced on the phone.
Dec 12, 2008 | Motorola Mobility RAZR V3
Blank screen on kyocera cell phone
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Blank screen
well the inside screen is blank but the outside screen isn't icant text or see menus i can stilll dial the numbers just cant see them on the screen
Apr 17, 2008 | Cell Phones
Blank screen
apparently you damaged your flex cable that connects the main board to the lcd - hence your calls work , but nothing on screen - to repair it costs - $25-40
http://horizonwirelessonline.com
Jan 23, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility RAZR V3 Logo
644 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
