Question about Hoover HWF5513E Front Load
Hoover HNWF7137 faulty in 20 minutes.\r\nDear sirs, I have a hoover washing mashine since three years ago & it's operating satisfactory, but suddenly the washing machine stops after 20 minutes from operation & a flush light blenking 7 times. we called the hoover dealer & repalced the motor first, the problem is still remaining the same, they replaced the main controller, the lock door, watre pump & the water solenoid valves, the problem wasn't resolved. kindly advice us what the problem can be & how we can resolve it. Thank in advance & we are waiting your feedback.
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Posted on Jul 16, 2007
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
SOURCE: washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Posted on Sep 10, 2008
SOURCE: the pump on my hoover washer hnf7148 has been
Have you checked the filter and the pipes to it? I have had problems with coins getting stuck in these pipes which can completely block them or can swivel in pipe so sometimes seems clear. I blew down the drain pipe to see if clear. I have to clear filter every few weeks which is a pain as it is at floor level. Will not buy another machine like this. By tipping up the machine you can remove the pipe behind the filter to get out coins are too large to reach the filter.
Posted on Aug 30, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
My new Hoover 2100 Model number PU 2110-001 stops for 20 minutes every 4-5 minutes of use. It seems to get too hot. It has done this since new, I have changed the dust bag & all filters, but it makes...
AS new return to shop, Not fit for purpose, they should replace it. sounds as if thermal fuse is tripping in the motor, resets itself when cooled down.
Mar 14, 2013 | Hoover Vacuums
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Sep 04, 2012 | Washing Machines
Hoover Nextra No Lights Not working
please check the fuse in the plug it should be13 amp it has no doubt blown after replacing it and happens again there might be a problem with the heating element it might be faulty or ruptured due to short circuit in the element eric
Dec 25, 2017 | Hoover AAA160 Front Load Washer
Hello. Would you send me a link of the manual OTSEIN LTO B86 (washing mashine) Many thanks
well i think u may have the number wrong it might be LTOH 86 B since otsein does not have any product by the number u have and i have the link for the manual however it is in spanish hope this is what u want since thay do not have the english version yet. http://www.hoover.it/libretti/libretto.cfm?id_line=9&filtro=&prodotto=6287&visualizzaListaProdotti=1
Sep 22, 2010 | Washing Machines
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has...
mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Jul 19, 2008 | Hoover Washing Machines
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Hoover HWF5513E Front Load Logo
50 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
