Question about Microsoft Windows XP Home Edition
Microsoft windows installer error 1603
I am new at this and don't know how to make such a folder. Sorry.
    Problem Solver:
  • 8 Answers
Its ok
press right click on the mouse wherever on the empty screen not on the file a dialog appears under new tag u will find folder click on it ana a new folder created at that place
best of luck
Posted on Jul 02, 2008
  • Gypsy Best Jul 02, 2008
    iohjkhjykhjkhjkh
Error code 1603
Anonymous,
At the link below is a Microsoft KB Article referencing the Error 1603, the cause and a Resolution.
Error 1603 You receive an error 1603 fatal error occurred during installation...
Thank You,
Dell-Jesse L
DellCares
Dell Social Media and Communities
Jul 19, 2014 | Dell Latitude E6440 BTX Laptop Computer -...
I have the same error msg when I uninstalled and reinstalled Skype. I am using windows XP
In some cases when you try to upgrade Skype from an earlier version to a newer version you may get the error message: "The Older version of Skype cannot be removed. Please contact your technical Support Group".
The error 1603 occurs during the process of uninstallation of the previous Skype version in case Skype is not able to find the cached PluginManager.msi file on your system.
First solution:
* Download and install Windows Installer CleanUp Utility from Microsoft site.
* Run the utility and remove "Skype Plugin Manager"
* Delete Skype\Plugin Manager folder manually. It is usually under folder C:\Program Files\Skype
* Install Skype 3.5.
Second Solution:
* Download the archive from:https://developer.sk...staller_fix.zip
* Unpack it to some folder. Make sure PluginManager.msi is located in same folder as fix.bat
* Run fix.bat Wait until the process is finished before proceeding
* Download version 3.5 and install it.
Feb 18, 2011 | Computers & Internet
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
Error 1603
When you try to install a Microsoft Windows Installer package, you may receive the following error message:
Error 1603: A fatal error occurred during installation.
If you click OK in the message box, the installation rolls back.
To resolve this problem, do any one of the following, depending on the cause of the problem:
  1. On the Windows desktop, double-click My Computer. The My Computer window appears.
  2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
  3. Click the Security tab.
  4. On the Security tab, do the following:
    • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
    • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.
    If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
    1. Click Add. The Select Users or Groups dialog box appears.
    2. In the Name field, click SYSTEM, and then click Add.
    3. Click OK.
  5. In the Permissions section, click to select the Full Control check box underAllow, and then click Advanced.
  6. Do the following:
    • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
    • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.
    Note If you receive a security message, click Yes.
  7. Wait for the operating system to apply the permissions that you have selected to all child folders.
  8. Run the Windows Installer package.
Encountered error message C00D11B1 while using Windows Media Player
There are different solutions on your problem here I did find some of them:
Try to use ccleaner and be sure that windows media player is checked :
http://www.ccleaner.com/
1: try to download this codek pack and install it :
http://www.free-codecs.com/download/XP_Codec_Pack.htm
2: it is related to updates your error you have to do this :
http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp
3: try to remove all the files from this folder- C:\Documents and Settings\All Users\DRM\- to a new subfolder and try this :
moving ALL the files in the folder: C:\ProgramData\Microsoft\Windows\DRM\ as well as the files in the “Cache” folder beneath that was the magic trick. I don’t know if you need to move from both folders, . Note that media player had to re-download the licenses. If it not work you can always return them from the folder back.
For more solutions please see here from the source link :
http://strom.wordpress.com/2007/04/06/windows-media-player-error-c00d11b1-solved/
Hope that helps
IF NOT then return here
Please rate my answer
Other support places :
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/default.aspx
Oct 07, 2009 | Computers & Internet
Microsoft windows xp home edition service pack 2 error 1603
Hello corejmwilli,
The 1603 error code your getting, is probably a conflick within the .net versions. I would go to remove programs and software in control panel, and delete any versions of .net that are there, and then you can download this one which is the most current. HERE. That should solve your provblem.
Good Luck
Mark
Jan 06, 2009 | Microsoft Windows XP Home Edition
Error 1603
http://support.microsoft.com/kb/834484
Jun 29, 2008 | Microsoft Windows XP Home Edition
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Microsoft Windows XP Home Edition Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
