Question about Vacuums
Pedal does not engage anymore
When I press the release pedal kit with my foot it does not come back to its origianal position. I pull the handle back up again but the pedal does not engage which is causing the vacuum to fall down. How do I fix it?
Thanks you very much
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
Posted on Nov 30, 2008
Install foot pedal release on riccar 8800 series
It's not hard to do but is almost impossible to explain how to do it. If you can look at one already installed on the shaft holding the pedal you can see how it's done. Visit your local Riccar dealer.
Jan 12, 2014 | Riccar Handle Release Foot Pedal - 8000...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
I'm a house sitter with this amazing vacuum, but don't know how to operate it in general. I simple need to vacuum the carpet. Please help me.
Unwind cord and plug it in
As you view the back of the machine, the foot pedal release is on the bottom left of the vacuum. Press this with your foot to enable you to lower vacuum into cleaning position.
Turn on and vacuum.
On/off switch is on the handle.
Aug 21, 2010 | Riccar 8955 Upright Vacuum
Self leveling platform will not lower.
Hi There,
This is probably being caused by the two little feet on the bottom of the agitator housing. I have yet to completely understand what the purpose of these two feet are, but what happens is that over time the screws that secure them in place begin to loosen, which allows these two little feet to become lodged between the agitator housing (the part the brush is actually in) and the vacuum bag housing (upright part) preventing the agitator housing from releasing when stepping on the foot pedal.
Here's a picture of these two little feet from the parts schematic. You may either tighten the screws, or just remove these two feet entirely from the vacuum cleaner, Other then helping stabalize the vacuum while in the upright position, these don't really seem to much else.
Here's the picutre of the two feet which are circled in red.
If you inspect these feet and they are not loose, then you may have an issue with the handle release pedal itself. Please just add a comment if this did not fix it, and I will be happy to walk you through step by step on how to fix the handle release.
I really hoped that this helped you fix the machine. If you found my repair helpful, please be so kind and rate the repair, or leave feedback for me. This is greatly appreciated by the Fixya community.
Thanks again,
Chris Jones
GoVacuum.com
May 12, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Hi, pressing the big red foot button on the dc25 lowers the cleaner to the working position,but it wont stand up again. would appreciate some help. thanks. TC
sounds like the ball cradle is worn out, the springs are too stretched to pull the handle release pedal back into place. you can do one of two things, replace the cradle assy, or just lift the red pedal up when you raise the handle
Feb 27, 2010 | Dyson DC25 All Floors Bagless Upright...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Broken upright locking mechanism
I need to know what brand the vacuum is. Various brands have different ways of locking the handle, but most incorporate a pedal that engages the handle. It sounds like you will have to replace the pedal. I hope it's not the handle portion. That becomes more complicated and expensive to replace.
Feb 08, 2008 | Vacuums
Handle foot pedal release U6425-900
I have the exact same problem. I can't even open the unit up. Let me know if you found anything out. I have searched the web and can't even find a service manual to purchase ! Thanks.
Apr 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
239 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
