Question about Sylvania Televison & Video
6632lg hdtv won't turn on
Turned off power strip to go on vacation for a week. Came back and TV won't turn on even after the 30 minute "reset" time. Other components turn on from the power strip but not the TV. I don't even have a standby light. None of the clocks in the house were flashing when we got back so there was no power interruption to the house.
  • jonesgang06 Jul 02, 2008
    I don't know how helpful yet as I haven't taken the back off the set yet.
  • 30 Answers
No stanby LED would indicate a power supply problem. check the main fuse and the 4 large diodes next to the fuse. one is common to short out and blow the fuse. i think D603
Hope this helps
Posted on Jul 20, 2009
    Champion:
  • 208 Answers
Unit does have a main power fuse on the power supply bd. that most likely opened. With no indicator lights at all that is usually all I find wrong. Might be as bad as a failed power supply but most likely just and open fuse.
Posted on Jun 29, 2008
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sylvania 6632LG won't turn on.
The power supply may have gone out, that is the first place to look, look for blown fuse, burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | Sylvania 6632LG 32 in. LCD HDTV
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Tv won't power on
I trashed the set and bought a new one.
Jul 02, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
400 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
