Question about Atari 2600 Console
Snowy image Hi, I got an old atari 2600, (1983). I tried it on my tv using a RF modulator i got from somewhere... which seems to automatically swith from antena to game when console is on. You know the one with two inputs. Results: I can see an image but there is no color, it is very snowy (70 %), but I can see that the cursor is moving and the action of the game. There is no sound. Is it the RF modulator which is no appropriate ? Do I need the manual RF switch you wrote about ? Or if there is a component busted in the console or a bad weld somewhere which need to be refresh. Please let me know what you think ? Thank you for the advice. Frank.
  • 2,794 Answers
Your going to need the manual RF modulator to get the sound out because it works off of a different output than the newer ones do. The 2600 runs a closed circuit TV signal to the modulator. In fact there is a small TV transmitter in the game unit.While most electronics today send a seperate audio and video signal. So a modulator that plugs into the electrical outlet won't do the trick.
I found this page on the internet. Look at the RF Option section and see what you think of those options:
http://www.cheeptech.com/2600mods/2600mods.shtml#rfoptions
Posted on Jun 30, 2008
Picture is snowy, sound also low
https://www.youtube.com/watch?v=o6nNfidRDa4
http://electronicsentimentalities.com/Assembled%20Mods.html
suspect either rf modulator has gone faulty
or analogue channel used has been re assigned to some other use and interference as cause .
Jan 23, 2016 | Atari 7800 Console
Own Atari 2600. Atari not responding to television. (FUZZY SCREEN) One of three problems: 1. I AM NOT CONNECTING SYSTEM CORRECTLY TO TV. please instruct me how. parts i have are: Radio...
Hello!
When powering the stuff there should be light indicated that there is a power on it. how ever if these not been observed, power adapter maybe busted. try to fix it or replace it. Please refer to the atari manual for the correct operation of your stuff.
hpe this help,
melnavz
Mar 14, 2008 | Video Game Consoles & Games
Atari 2600, only get black and white, no color
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
Dec 14, 2011 | Atari 2600 Console
I found my dads atari set from the 70's or 80's, how can I hook it up to our current tv?
Try getting an RF Modulator from somewhere like Radio Shack...you can run it through that, into the TV.
Here are a couple of links I found that might help you out more though...
http://www.wikihow.com/Hook-Up-an-Atari-to-a-Modern-Television-Set
http://www.youtube.com/watch?v=38os4_ama08 is a video I found on YouTube...this guy seems to really know what he's talking about. Just ignore or skip past the part regarding how to buy an Atari, since you already are lucky enough to have one...
Dec 21, 2010 | Atari Video Game Consoles & Games
Tried connecting direct to both an LCD and older set using the coaxial lead straight from the console.Cannot get anything at all.Do I need an rf modulator or no.
Quite the opposite - The Atari 2600 sends a modulated RF signal over the cable, it needs to go to the ANTENNA port of the TV, and you need an adapter. On eBay, look for
ATARI 2600 RF TV SHIELDED CABLE + ADAPTER
http://www.atariage.com/howto/connect.html is a really good guide.
Nov 26, 2010 | Atari 2600 Console
My atari wont boot the game no matter what game i try it just displayes snow
Well I think it is the rf switch thats causing the tv to have a snowy tv screen then.
Nov 18, 2010 | Atari 2600 Console
2600 atari
To connect your Atari to your TV, you'll need to get a "phono to f" adapter. These are available at RadioShack (part no. 278-255) for about $5.00 This adapter takes the phono plug from the Atari and changes it to a standard coaxial adapter. If your HD TV doesn't have an input for standard cable wires, you'll need to get yourself an RF modulator to switch the coax to RCA. If you have an old VCR with an unused cable input, that will work as well.
Mar 28, 2008 | Atari 2600 Console
ARTARI 2600 HOOK-UP INFO?
yeah its the right thing. Hook the RF Modulator to the cable connector on the back of your TV. (the one with the threads) and hook the cable from your Atari (its a AV cable) to the RF Modulator. set the little swithch on your Atari to chanel 3 or 4, then set your TV the the same channel and enjoy your Retro Gaming goodness (I Love My Atari 2600)
Dec 25, 2007 | Atari 2600 Console
Atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Dec 23, 2007 | Atari 2600 Console
No A/V!
DOES THE SYSTEM POWER LITE GO ON? IF SO THE PROBLEM IS MOST LIKELY A DIRTY GAME. YOU NEED TO CLEAN EVERY GAME BEFORE PUTTING IT IN. MIX ALCOHOL AND WATER, 1 TO 1 AND USE A Q TIP TO CO UP AND DOWN THE CONTACTS. IF THEY ARE BEHIND A PLASTIC DOOR, STICK A SMALL SCREWDRIVER IN THE HOLE AND IT WILL MOVE BACK. OTHER THAN THAT, YOU SEEM TO HAVE DONE EVERYTHING RIGHT.
Aug 30, 2007 | Atari 7800 Console
Atari 2600 Console Logo
270 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Iron
Iron
Reggie brown
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
