Question about Carrier Heating & Cooling
Not blowing upstairs not coolin - Carrier Heating & Cooling
  • cpthillary55 Jun 29, 2008
    carrier ac model number 38TRA048-3, I have already checked the fuses- they are ok, it makes a funny noise, like a tiny dull booming sound as it's running. the outside fan is running ok, not frosted
    Genius:
  • 3,422 Answers
The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Posted on Jun 29, 2008
My air conditioning unit is leaking water on the ground outside. Also the air upstairs in not coming out. It's working in the basement. What could be the problem?
It is normal for an air conditioner to drain water outside.
The lack of air flow upstairs could be due to closed or blocked registers.
Aug 07, 2017 | Heating & Cooling
Why is my coolin fan fuse keeps blowing on my 1999 Saab 9-5 2.3L Turbo.
Probably because the fan is bad. Does it blow right away or after a while? Get another fan, plug it in before replacing and see if it blow the fuse. If not, it's the fan. Or, simply unplug the fan and see if the fuse blows. This will eliminate a short in the wiring, etc.
Aug 23, 2010 | 1999 Saab 9-5
Visit coolin work shop
you will need to go the authorised to service and reset the CPU.
Jun 28, 2010 | 2002 Mercedes-Benz C-Class
Electric Heater Only works on Emergency Heat Setting.
I would say that you are on the right track.
Jan 11, 2010 | Heating & Cooling
My ac blows warm air upstairs only but not downstairs in winter
Sounds like you have a zone system? Is it a bypass type? If it is the fan speed of the heater must be to slow to override the bypass damper. Wire the fan to operate at a single speed same speed as on the A/C.
Jan 05, 2010 | Heating & Cooling
On my 2000 Jimmy when I'm at low speeds in the city it usually blows quite warm out of the heater (not always). But suddenly it will quit blowing any heat at all. On the highway it just blows cold. The...
Hello. First, it is probably that the clotch in the coolin fan isn't working. When the coolin fluid is warm, the temperatur put it in work, and the fan works rapidly, when the temperatur lows, the clotch loose the fan an is waiting the warm up again. But your Jimmy don't have the coolin fan in the principal belt, it have an electric coolin fan. In that case, your problen is for a low level of coolin water, or the relays of the electric fan don't work properly.
Finaly, my english isn't good, because I speak in spanish, but if my bad english solves your problem, i'm geting so well. I working every day in electronics cars, and that is the basic metod of analyse that I use.
Dec 21, 2009 | 2000 GMC Jimmy
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Heating & Cooling Logo
79 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
