Question about Whirlpool LBR4132JQ Top Load Washer
Washer not spin cycle or Drain
When going to the spin cycle it will not do nothing
  • 154 Answers
It maybe the timer has a fault in it. You should have a spin cycle on the other side try useing the drain and spin on that side. If that doesn't work replace the timer. Also if you are able to, undo the control panel should only be 3 screws on the back and make sure no wires have dropped off the timer panel. But please unplug it first
Posted on Jul 21, 2008
Washer won't spin or drain
My bet would be that the timer got damaged as a result of someone rotating it backwards to rejigger the wash cycle.
Jun 04, 2016 | Whirlpool Washing Machines
My washer started just find, then have way through the wash it stoped dispensing water and will not drain. Tried spin cycle only, and nothing. Tried unpluging, and still same problem Tried restarting...
all frontloaders have to start the drain pump before any cycle will start ... if there is something stuck in drain pump or hose between bottom of wash tub to pump washer will not spin... check filter pump assymbley and drain pump
Jan 24, 2011 | Frigidaire Washing Machines
Our washer quit going into going cycle yesterday.
one click clockwise to see if will start if not start check carbons
Dec 20, 2009 | Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Will not drain/spin. Yesterday, the load was out of balance...
Try unplugging the washer and let the curcuit board reboot. Unplug for 5 min. Then try moving the selector to spin to drain the washer. Sometime selecting too many modes trying to get something working can confuse the electronics. Reboot the curcuit board and try just spin cycle.
Apr 29, 2009 | Washing Machines
My washer will not spin or drain
most washers have a timer relay if it has started to go out this is one of the problems that can happen so check thie timer relay it is the big nob you turn to start your washer. Just so you know sometimes the relay cost more then a new washer but it's worth cecking out.
Feb 18, 2009 | Whirlpool Inglis IP4400 Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool LBR4132JQ Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
