Question about Packard Bell Easy One Silver 2101 Notebook
Packard belleasy one silver
Switch on fan and hard drive spin but no display can not get into bios not sure if the switches under the keyboard are set correctly did work and boot up when i got it ???
    Genius:
  • 2,028 Answers
Occasionally this is an indicator that the hard drive has failed, it recognizes the hard drive and tries to boot from it, but the hard drive continuously spins without booting. Try removing the hard drive and going into the bios. If you can get to the bios without the hard drive, then the drive has failed and needs replaced. If you still cannot get to the bios, then the problem may lie with the motherboard or a corrupt bios and will need to be checked out by a tech. Also check the memory chips, rare, but occasionally this will cause these symptoms.
Posted on Jun 30, 2008
When boiting is attempted, the hard drive spins up and the fans turn on, even the cd drive opens, but nothing is displayed on my moniter
means no display right .....press f8 when switching on......may be the resolution problem.......otherwise press del or f1 to go into bios......still no display.......motherboard has internal problem give it to service center
May 08, 2012 | Dell Dimension 8100 PC Desktop
I forgot my bios password compaq presario 900 password bios cen you help my
Before removing the RTC battery, follow these steps:1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn thecomputer on, and then shut it down through the operating system.2. Disconnect all external devices connected to the computer.3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet andthen unplugging the AC adapter from the computer.4. Remove the battery (see Battery on page 34).5. Remove the following components:a. Hard drive (see Hard drive on page 37)b. Optical drive (see Optical drive on page 44)c. Switch cover and keyboard (see Switch cover and keyboard on page 46)d. Display assembly (see Display assembly on page 50)e. Top cover (see Top cover on page 55)f. Fan (see Fan on page 58)g. System board (see System board on page 60)Remove the RTC battery:1. Turn the system board upside down, with the audio connectors toward you.
found here: http://h10032.www1.hp.com/ctg/Manual/c01295803.pdf page 65. you'll have to pull the battery for 5 minutes and then reinstall and all cmos passwords should be cleared! good luck
Jan 27, 2012 | Compaq Presario Notebook
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I am troubleshooting a Pavillion Slimline s3100n desktop pc, approximately 2 years old. It will not power on. When pressing the power button or plugging in the PC, the power switch illuminates, the fan...
It sounds as if your processor is on its way out of your Hard Drive is buggered. try another HD and if this works then its the HD. If it doesnt its your processor in which case you may aswell buy a new computer
May 20, 2010 | HP Hewlett Packard Pavilion Slimline...
Can someone please tell me where the hard drive of Easy one is?
Take out the floppy drive and it is sat on the top. the floppy drive is the craddle for it.
Apr 17, 2009 | Packard Bell Easy One Silver 2101 Notebook
Newly build computer problems
i bet your power supply isnt powerful enuf for your video card.
Jan 31, 2009 | ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom...
My PB Easynote R1938 refuses to boot/start up!
Hi. You may have disconnected the fan by mistake when unscrewing it, so the laptop closes down when the system detects the fan isn't working. I would check the fan. It should have a tiny cable which plugs into the motherboard.
Otherwise the only solution may be to remove the hard drive and install it in another laptop, then you can access the data from there.
Jan 03, 2009 | Packard Bell Easy One Silver 2101 Notebook
BIOS beep codes on packard bell home pc
You need to check your RAM, make sure it is seated properly.. this should fix the problem!
Sep 18, 2008 | Packard Bell Easy One Silver 2101 Notebook
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Packard Bell Easy One Silver 2101 Notebook Logo
111 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
