posted by denny76 on Jun 29, 2008
Certificate has expired and Widows Vista blocks active-x download from camera. How do you work around this?
Best Solution
posted on Aug 13, 2008
Using the OPTIONS menu of IE, select SECURITY. Scroll through and find the check boxes for downloading unsigned and expired ActiveX code. Remember what the current setting is, then uncheck the setting to temporarily allow expired or unsigned ActiveX programs to download.
Try your Veo Observer again, download the ActiveX and when you are sure it is working, go back to IE OPTIONS and change your ActiveX options back to their previous settings, which was to NOT allow expired or unsigned ActiveX code to download..
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Veo Observer Network Camera
Email this problem
Email this problem
Can you Help with these Web Cameras problems?
i need step by instruction to...
I'm running Vista in one... Answer This...
Veo Observer Gears are broken
Love the Veo. I ended up moving... Answer This...
i wite wrong firmware to my 602...
hello ! i write 416 firmware... Answer This...
Repair Service
Find Web Camera Repairman Near You:
